I have a mitsubishi 55511 television. I had a power surge and the power button shows a constant green flashing light and will not power up. I can hear a clicking in the av tuner, dm power box. I replaced the 7 DM Power supply 16 W fuses with 35 W fuses but the problem still persisted
  • Frederick Frost Nov 13, 2010
    I have already done all that. This is a common problem with all Mitsubishi Tv's that are rear projection from that period (2003) thats why I replaced the fuses in the DM power supply but I'm not sure I got them in right because the 35 watt fuses were quite a bit larger than the 16w fuses and they were real crowded going in. I wonder of some of the sodier welds are not good.
  • Frederick Frost Nov 14, 2010
    The fuses were not it. I am not sure how to disconnect the front pannel volume control. Do I just look for the wires and follow them to the board and disconnect? won't that also disconnect the sensor for the remote?
  • 4,889 Answers
Did you try the self-diagnostic called error code operational check? If yes then what is the error code that you get?
Posted on Nov 14, 2010
  • 5,138 Answers
Front Panel board the one that has power/CH- CH+ Vol_ Vol+ disconnected it and wait 70secs then with remote hand unit see if TV will turn on,if it comes on then you need to replace the front panel board or all of the contact switches on it.
Posted on Nov 13, 2010
  • 1 more comment
  • ladywinn
    ladywinn Nov 13, 2010
    Im a little confused because its 7 capacitors on the DM board that you have to replace they are 1000uf 25v use 35v capacitors most of the time its 5 all in a circle on the DM board.
  • ladywinn
    Capacitors are bad if they are swollen,vented or puffed up on Top.
  • ladywinn
    ladywinn Nov 14, 2010
    Senser is not on the front panel board and yes folow the wires and disconnect the plug in on board.
I recently was given a mitsubishi ws-55511 55 in tv it has the blinking green timer light that keeps flashing what might be the problem and any idea on repair cost?
First you can try pushing the reset button located on front of tv where power button is located. If that fails to correct the problem then I would suspect the DM module has failed. They are not available for replacement. Some shops rebuild them by replacing the defective capacitors with some success others might send it to a company such as PTS to be rebuilt also with some success. Repair prices will vary from 275.00 - 375.00 depending on your location
Nov 21, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Timer light is flashing and the set will not turn on
i need your confirmation that we can handle the repair we need to remove back cover and repair by parts.
Apr 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
We lost power last night. we have a surge protector on the house. the tv flashes green power button but does not turn on
Replace Both of your STK ICs they are big black ICs will have Part number on them Call Mats 1-800-628-1118 example STK392-570
Dec 03, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Won't turn on after reset ws-55511 hdtv
YOU GOTTA REPLCE THE STK ICS OR THE CAPS ON THE DM BOARD
Jul 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV will not switch on, green light flashes for 30 seconds but it still does not come on.
know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Dec 14, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
