Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
  • 270 Answers
It is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Posted on Nov 13, 2010
Changing filter
Where is filter on Hotpoint Aquarius WD420
Oct 14, 2012 | Hotpoint Aquarius WD640 Front Load...
Sometimes when using the tumble dryer of my Hotpoint WD420 I get a puddle of water on the floor. Doesn't happen with every use. Do you know what the problem might be?
I suspect your dryer vent is blocked or partially clogged.. Also if your washer is not opperating properly putting wet close in the dryer could also cause this.....hope this helps!
Feb 19, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
I have a hotpoint wd420. the door light is flashing the wash light is on constant and the machine wont work anyone any solutions please!!
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
Nov 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint wd420 is leaking water from out the dispensor and door on a rinse/spin cycle.
You ne to get yure rubber seals checked and changed it sounds like they have perished
Nov 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wd420 not pumping
Hi,I have just been on a service call to the same model,the pump windings had shorted turns and after replacing the pump i have found that it has also damaged the module(pcb assembley) not good considering the module is 120 uk sterling!!
Feb 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
1,170 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
