Installation manual for GEA AHLBORN Plate Heat Exchanger Type VT-10
I need a manual for a Ahlborn-Galanti Chronciler organ where can I find one?
Your best bet would be to contact the manufacturer. Here is a link to their contact info.
Ahlborn Galanti MITA International
Feb 11, 2015 | Music
Why is my Rinnai Infinity 20 leaking?
Hole in heat exchanger caused by improper condensate drain?
Read installation manual, call service technician.
http://waterheatertimer.org/pdf/Rinnai-Tankless-Troubleshooting-Manual-2012.pdf
Replace with tank type heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Oct 01, 2014 | Rinnai Water Heaters
Where is the heat exchange in a rheem pool heater located ?
The PVC plumbing is hooked into the front header, the front header is attached to the heat exchanger. The heat exchanger looks like copper finned tubes with a steel plate on each end. You need to disassemble heater working from top down to get to the exchanger. A skilled tech can replace an exchanger in under one hour service call.
Aug 19, 2014 | Rheem 266K to 399K BTU Swimming Pool...
Did not receive owners manual with new G.E.dishwasher model#GDWF160RSS
Hi! I hope this link will provide the information you need: http://genet.geappliances.com/search/search?site=gea-litlib_collection&client=gea-litlib_frontend&output=xml_no_dtd&proxystylesheet=gea-litlib_frontend&filter=0&getfields=*&tlen=150&q=GDWF160RSS
Follow this link and there you can find these documents (requires Adobe Reader): 1. Quick Specs, 2. Energy Guide, 3. Installation Instructions, 4. Use and Care Manual.
If you have any trouble or you can't access that link, please don't hesitate to contact me. Have a nice day!
Sep 01, 2011 | Dishwashers
Just had some work done on a Goodman GMPN060 and was told the heat exchange had a crack in it. Checked and the part itself is under warranty excluding labor. Just wondered how big a job it is and if...
you correct these heat exchangers are either warrantied for 15-20 years on the units... but the labor usually is not.... been appliance/heating /and air conditioning business owner for approx. 10 years now and in the business a little over 18 years .. the heat exchanger labor usually runs around 600.00- 800.00 when we do these jobs under warranty... it requires diassembly of practically the entire unit in order to do it correctly... and that usually requires unistalling the unit and re-installing in order to get the job done.,,, if the unit is over 12-15 years old we usually recommend replacement ,but does not have to be the finally result... as far as changing it out i won't say it cant be done by a home owner it is alot of screws and like i said requires diassembly of the burner chamber ,combustion motor ,flue piing,gas valve,any safety switches and wiring in the way...the heat exchanger is located on the burner side of the furnace in behind all this is the burner tubes and a plate that has to be removed to gain access to the heat exchanger. it not all that difficult just time consuming... as far as a diagram or step by step instructions i am not aware of any available.. they do have instructions in the new heat exchanger that gives a brief description of what required and a picture or two on it... 5k seems a little expensive too... i am in the dallas /ft.worth metroplex and we charge on the average 3500.00 to install new furnace unless there is special circumstances or going to be a real chore requiring several guys... hope this helps good luck ....
Feb 12, 2011 | Goodman Heating & Cooling
Have lost the plate for my vanguard vt-840 tripod
The part you are looking for is the Vanguard QS-10.
Get it via mail order here:
http://shop.thefotogeeks.com/vanguardvt-840quickreleaseplate.aspx
or ebay:
http://cgi.ebay.com/Vanguard-QS-10-Quick-Release-Plates-/170479531839e
Mar 05, 2010 | Photography
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
