Question about Sharp AR-5320 Black and White Copier
It is giving h2 error - Sharp AR-5320 Black and White Copier
Press # Introupt C introupt 14 Start Or Press # Introupt C introupt Start 15 or Press # Introupt C introupt Start 16 or Press # Introupt C introupt 17 Start ,
One Of The Above Will Solve The Problem iF Not Call Service
When You Press # Introupt C introupt Display goes off then press 14 or 15 or 16, or 17 then
Start . Mine Was Back In Sevice By
Posted on Nov 28, 2010
Bosch tankless water heater error h2
H2 wasnt an error code on those machines... could you check the display and ask again?
Feb 11, 2014 | Bosch & Tankless LP Hot Water Heater
Display error H2
Gwnerally in sharp you cancel H2 doing a reset through code 14. did you do it yet?
Dec 03, 2011 | Office Equipment & Supplies
As i give password fo openig yahoo mail, it shows error 404
It may be happen for the problem of servers. But you double checked the password and your username. If these are write you try again some times later I aside you that you will succeed in this time. Thanks
AnthonyTuition is a small group tuition based in the northern area of Singapore, specialising in H2 Maths and H2 Physics Tuition
May 21, 2011 | Yahoo Mail
E 91 01 THE FLASH DOESNT WORK AND IT GIVES THIS ERROR CODE
Just go in "menu", "set up 1", "initialize", and select "ok". With that you will reestart your camera. I already did it twice in my DSC-H2 and the flash came back to work. Goo Luck!!
Jan 31, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
What does it mean when h is flashing
There is a problem with the fuser unit , H2 means thermistor open or not connected, H4 means low temperature or fuser lamp not working. Reset with by pressing ; # , Interrupt , C , Interrupt. Display will go off then enter 14 and press Print key.
Jul 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
Model AR 5320E. Giving H2 error.
As we needed our copier very quick we had to call a qualified person to arrange the system.
Kind regards
Miriam4177
Jun 17, 2009 | Sharp AR-5320 Black and White Copier
I just buy it and whene i plug it ,it gives code ou-80,h2-00
Your error code indicates that the Fuser is not at the correct temperature, which can lead to smeary smudgy copies or scorched paper and a fire hazard, depending upon whether the fuser is too cold or too hot.
Replace the Fuser Unit.
Apr 26, 2009 | Sharp AR-C150 Copier
Unit ig giving a 2H error code
the problem is h2 not 2h you need to replace the thermistor or try to clean it by an ordinary cloth
Jun 17, 2008 | Sharp AR-153E Copier
H2 Error
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
Dec 31, 2007 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
