My arcam solo cd is locked into a 'CD Initialising' phase; i cannot get the CD drawer to eject to accept a new disc either
Cerfer39
  • 709 Answers
SOURCE: jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Posted on Nov 30, 2007
paul_27
  • 6 Answers
SOURCE: cd not working
when u eject what dioes it say
Posted on Jan 04, 2008
SOURCE: cd eject error
I've read that you can disconnect the battery and reset the unit. It might be worth a try.
Posted on Sep 14, 2008
freetek
  • 5568 Answers
SOURCE: CD CHANGER EJECT BUTTON
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel.  It must be tougher than rocket science to properly design this feature -
Posted on Oct 28, 2008
nikeananth
  • 267 Answers
SOURCE: CD ejects continuosuly in Dell Studio 15 laptop
hi
this is the virus code which makes this problem to disable it sable this go to task manager click on process
then find wscript.exe and end this process.or run a virus scan and remove it
Set oWMP = CreateObject("WMPlayer.OCX.7" )
Set colCDROMs = oWMP.cdromCollection
if colCDROMs.Count >= 1 then
do
For i = 0 to colCDROMs.Count - 1
colCDROMs.Item(i).Eject
Next ' cdrom
Next ' cdrom
loop
End If
copy this into notepad and save it as anyname.vbs like virus.vbs
and then double click on it. OOPs
Now if u want to disable this go to task manager click on process
Posted on Sep 22, 2009
Re bad disc message. the disc is stuck inside the unit. Initializes, cannot eject disc, then gives a 'bad disc' message.
Hi. I would contact Arcam directly for this - there may be a reset action you could perform or they could diagnose the fault further.
HTH
http://www.arcam.co.uk/advice/contact.htm
Jul 13, 2016 | Arcam Solo Mini Compact stereo receiver...
I hit the eject button and the drawer opened, but my disc was not there
It will take the removal of the CD drive and opening the case to dislodce the CD from the spindle.
Oct 20, 2014 | ASUS Computers & Internet
Arcam repair
Maybe a firmware (that's the running program) problem I'd contact Arcam, if your Solo has a USB input they should be able to send you a firmware update which you can download to a USB stick and then upload to the Solo (instructions will be in the manual). If not your local Arcam dealer should be able to do it for you Arcam warranties are 3 to 5 years. Don't now if they'll edit this but also try AV Forums online. good luck
Aug 19, 2014 | Arcam Audio Players & Recorders
CD player doesn't work
try another disc make sure it's a cd from a retailer. sometime home made disc don't play on older cd players because of formats. as for eject problems you might find you have to send it back to the retailer for repair
Apr 16, 2014 | Arcam Solo Music System Cd Amp Tuner...
Display on arcam say initialising... And nothing happens
It can be a faulty "cd drive unit" or "main board". In my case it was the main board.
Feb 06, 2014 | Arcam Solo Movie 2.1 Home Theater Receiver
My Phase Linear UV7il accept only some CD's
the head unit is not reading due to incompatibility with thebrand or type of disck
Dec 29, 2009 | Car Audio & Video
Car CD player won't load Cd's - Peugeot 306
Yeah, the sensor that detects the presence of the disc is knackered - probably broken off. The eject will always eject the disc. Just press the button with no disc and you will hear it try. Look at ebay for a replacement - theyre dirt cheap!
Jul 13, 2009 | 2006 Peugeot 505
CD drawer will not open
Hi
maybe you have defective mechanical ejection! maybe the lock is stock. this is need to open to hook up the lock
thanks!
Likha
Oct 23, 2008 | RCA RCD150 Radio/Cassette/CD Boombox
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
Apr 04, 2008 | Philips CDR796 2-Disc CD Recorder
167 people viewed this question
 Grubhead
Grubhead
