Question about Pride Jazzy 1103 Ultra Indoor Power Wheelchair
The controler cable cought on something and pulled out, breaking the connection between the two cables .. I cut off both ends and soldered the 6 wires togather .. Lights flash .. I took the controler apart and ohm tested all the wires .. all good .. still flashing ..
  • wcdoc1953
    wcdoc1953 Nov 13, 2010
    What is the flash code? I am assuming you soldered 6 wires on the redel cable of a Penny and Giles remote plus Joystick control. There is a flying lead on the hand control, a wiring harness that goes to the base and a connector at the base. Can you see any other physical breaks?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hello,visit:- www.alldatasheet.com its what it says alldata on everything,its free & you can download as PDF File save to your Adobe Reader + print for future ref.im disabled myself & know what its like to be stranded.Have a nice day Colin.
Posted on Nov 18, 2010
How do I troubleshoot a 'no signal' issue?
It sounds as if the 1/4" jack has become faulty. The only other thing would be a cord with a break in the interior wire, causing and intermittent connection and signal transfer. I have had this happen with repeated stage use. I tested the cord with an ohm meter attached to each end of the cord wire and starded bending the cord, going from one end to the other. Mine was broke about 4" from one end and would loose signal with the slightest motion. I cut the cable about 6" past that point and re-soldered the wire and still use the fixed cable. Good Luck
Sep 02, 2014 | Music
None of the ear pieces work only if I move around the Jack plug thing
sounds like the jack is faulty tghe cable has been pulled and the wire probably stripped off connectors. if you can access a electronics or audio shop purchase a new jack these are cheap and you will need to cut the end off the cable there should be three wires an earth and a left and right cable these will need to be resoldered on the new jack plug.. make sure it is a stereo jack...!!.the best way to solder is to gently heat the cable end and dab a bit of solder on each before trying to attach to the jack. then when you come to connect the jack end lightly touch the connector and cable together with solder iron and solder..good luck A
Aug 13, 2010 | JVC Gumy Ear Bud Headphone - Peppermint...
Car window defrost
CHECK VACUME HOSES UNDER DASH
Dec 18, 2009 | 2004 Chevrolet Cavalier
My sony mdr-7506 headphones stopped working, anyway to fix them, i love them
As long as there is no inbuilt amp or something special to this make, then the problem will be most likely the cable or the Jack plug at the end. There will have a clean break (internal) cutting off all sound. If you are good with a soldering iron then you should be able to get a new cable with plug, or you can try cutting the old jack and fitting a new plug. If you need to go inside to fit the cable then the access screws will be under the foam and ear pads.
Dec 14, 2009 | Sony MDR-7506 Professional Headphones
My phone line comes through a cable modem. how do i connect
well no promises but this may work
items you will need
2 coaxial cables
3 way coaxial splitter
1 old phone cable you can sacrifice
soldering iron (optional)
solder (optional)
steps,
take a coaxial cable and cut on of the ends off, throw the severed end away and strip the insulation of the coaxial cable (only strip about 3 inches of it away.
seperate the coper (or sliver wire) from the wire center wire and twist toeghter to make a neat wire
strip some of the insulation away from the white center post revealing the coper wire inside
cut end off phone cable and take about 4 inched of insulation away
5
connect the green wire of the phone cable to the copper outter most wire of the coaxial cable and tape it so that there isnt any of the outer most wire showing
6
connect the white wire to the center wire of the coaxial cable and tape so that there isnt any wire showing
7
connect the coaxial/phone cable you just made to the 3 way splitter
8
connect the coaxial line that comes from your house to the splitter
9
connect the other coaxail cable to the last available port on the splitter
10
connect the non-modified coxial line to your modem/router
11
connect the phone cable to the fax
this might work, no promises, i havent tried it, but it might work and is worth a try
Jun 14, 2009 | Brother MFC-5460CN All-In-One InkJet...
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
My sirius car antenna cable got cut by the trunk closing on it. I tried connecting the two ends and the system can not get a signal. What can I do?
Small heat gun.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 07, 2009 | Sirius Satellite Radio Receiver
How do I find and replace the vga cable? (It is hardwired to the back of the monitor.)
I got hold of an old vga cable (15 pin), cut off the male end. I then cut the existing cable comming out of the monitor. After soldering the wires together and lots of electrical tape wala - it works.
Now the problems I incured - Don't solder wires together based on color, they probably will not match. Peel back the ends of the cut off connectors and find each pin with a Multimeter. Once you find each wires match solder them carefully and tape. When done test and if good place a short splint on the spliced area and tape. This will keep the wires from breaking from movement. Good luck.
May 24, 2009 | Sylvania SF150 15" Flat Panel LCD Monitor
Cable break!
1. clear cut off the damaged section,
2..solder or ideally wire-wound the connections,
3. insulate the wires with plastic tape, or plastic sheet,
4. shield the wires with aluminum foils,
5. wrap up the outer.
6. done.
good luck
pc-cook
Nov 19, 2007 | Fishman Full Circle Upright Bass Pickup...
Pride Jazzy 1103 Ultra Indoor Power Wheelchair Logo
65 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
