Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
I need a fuel pump for a lser 72. any one know were i can get one
  • 674 Answers
I may have a used one. You can contact me at nitensheaterservice@earthlink.net
Posted on Nov 14, 2010
Donde comprar puntero laser?
He encontrado estos punteros l?ser a la venta: http://www.comprarlaser.com/
¿Sabe usted acerca de estas cosas? ¡¡¡Es peligroso!!!
Jul 26, 2016 | Office Equipment & Supplies
Check engine light codes 12 42 72 55
12, Direct battery input to PCM was disconnected within the last 50 Key-on cycles 42 .An open or shorted condition detected in the auto shutdown relay circuit.
An open condition detected in the ASD relay output circuit.
An open or shorted condition detected in the fuel pump relay control circuit.
An open circuit between PCM and fuel gauge sending unit.
Circuit shorted to voltage between PCM and fuel gauge sending unit.
No movement of fuel level sender detected.
72, Catalyst efficiency below required level. (Same as code 64) 55, Completion of fault code display on Check Engine lamp
Jul 15, 2011 | Jeep Cherokee Cars & Trucks
99 4.0 started running real rough under load
sounds like a weak fuel pump.Check fuel pressure if not within specs replace pump.It should be 56-72 psi with key on engine off.
Apr 26, 2011 | 1999 Ford Ranger SuperCab
My 89 f1-150 fuel pump takes 10 minutes to shut off when egnition is turned on it wont start until fuel pump shuts off
I would say the fuel pump is worn out or filter screen that is attached to fuel pump is clogged..
have you ever changed the in line fuel filter ?....I have never heard of this problem...
I wouldnt hesitate to change the fuel pump and in line fuel filter.......
One test you can try .....Get a good drain pan disconnect front line from in line fuel filter...rather than using a pressure gauge to save time turn ignition on and watch how fuel is dispensed into drain pan....you will be able to verify if it is bad....considering the age of vehicle it is surely clogged and or worn unless you have changed the pump,and filter and also cleaned the tank before...
Because all have trash in them......I think you are lucky to have that year of truck...I have a 98 F150
but I do long to have about a 72 model...WHAT engine is it ....IS it fuel injected ...?
This will help diagnosis but you may have just bought it....................I do not know
Mar 02, 2011 | 1989 Ford F 150
I HAVE A LASER 72 WILL NOT HEAT GOT A COAD EE 2
EE 2 has several possible causes.
1. Fuel problem
2. Dirty flame rod
3. Bad igniter
4. Circuit board
If the fuel pump makes a loud ticking or thumping sound, you have a fuel problem. The pump makes this sound because no fuel is getting to it. This can be cause by a dirty filter at your tank, a dirty fuel strainer in the fuel sump, you are out of fuel, or have an air bubble in the fuel line.
If the flame rod is dirty, the heater will light then go out after about a minute.
If the igniter is bad the igniter will not light at all. You can test the igniter with an ohmmeter. The resistance reading should be around 17.2 ohms. I usually just use a clamp on ammeter and see if the igniter is drawing any amps when it is starting. If it is, it is good.
You can check for voltage where the igniter connects to the circuit board. It should be 120vac. If not your circuit board could be bad.
Let me know if you need a better explanation of anything. Hope this helps.
Oct 07, 2010 | Rinnai Toyostove Direct Vent Heater:...
The hot feed wire for fuel tank where does it come from and how many volts should it read
1995 chevy 1500 pickup. no power to fuel pump. possible wires got cut.need fuel pump wire diag to trace.thank you.
May 10, 2009 | Chevrolet C1500 Cars & Trucks
72 Pontiac GTO, been sitting for 8 years. I can't
You hit the nail on the head. Chances are the sending unit filter "sock" is clogged. Most of the time you can clear it by blowing compressed air back through the tank.
I would however, inspect the suction line from the fuel pump to the tank for rust obstruction and hoses for de-lamination.
Disconnect the line just before it goes into the tank and try to blow air through it just to make sure it is not rusted shut.
Good luck, let me know.
Regards,
Mar 23, 2009 | 1988 GMC S-15
No power at fuel pump checked fuses their good
check for power at the fuel pump relay kdc744
Feb 08, 2009 | 1988 Mazda MX-6
The reset button comes on for laser 72
The thumping noise is the fuel pump starving for fuel. It sould like you are having a fuel problem. NO fuel, low fuel, dirty filter.
Tom Hawkins
hawkins111@gci.net
Jan 03, 2009 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
96 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
