Question about Canon LASER SHOT LBP-2900 Printer
I couldn't print both sides of paper using this printer.let me know the solution for this plzz.!
  • 132 Answers
There is not solution - Canon LASER SHOT LBP-2900 can print one side only. For print to other side, you must print one side, then put paper manually for print on other side.
Posted on Nov 13, 2010
Testimonial: "thank u"
My printer is only pulling the paper in from one side, have tried cleaning the rollers and have checked for foriegn objects in the paper feed, display reads no paper, any ideas?
My problem too, solved it easy, couldn't believe it, a pen had fallen in the paper feed slot, I didn't think it possible, couldn't see it until I took it to bits, be careful but worth a look
Sep 23, 2012 | Canon PIXMA MX310 All-In-One Printer
Ir3300 black page coming how to rectified this problem plzz help
True multi-functionality means you get more for your money in less space with the iR3300 black and white office photocopier. Handling the work of many in one compact solution, the iR3300 provides a cost-effective solution to your printing needs.
Features of the iR3300:
  • Provides copying, printing, scanning and faxing all in one unit.
  • Has a print speed of 33 pages per minute .
  • High capacity paper supply
  • Double-sided printing as standard.
  • Compact and reliable design.
  • Productive and space saving finishing options.
Jul 22, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
My HPSC 1500 PRINTER , KEEPS INDICATING THERE IS NO PAPER , AND WILL NOT PRINT
Dear Sir,
This is the error of empty paper tary so u plzz fill paper and restart power of printer and try to print
Thanks For Your Time,
Apr 07, 2010 | Office Equipment & Supplies
How can I print on both sides of paper?
Unless your printer has a "duplex" feature, you'll have to manually take the paper out, flip it over and put it back in to print on the other side.
Feb 26, 2010 | Canon Pixma MP500 All-In-One InkJet...
Hp l7590b no paper load
hi friend,
Step 1Turn on your printer. Make sure it is plugged into an electrical outlet and installed properly.
  • Step 2Wait for your printer to stop. Do not load paper while it is printing or running any kind of maintenance operation.
  • Step 3Prepare your paper. Make sure your paper is right side up (glossy, whiter or label side should be facing up). Make sure all the pages are lined up together, like a deck of cards.
  • Step 4Locate your paper tray. Some printers have a manual tray and an automatic feed tray. Refer to your printer’s documentation to find the automatic feed paper tray.
  • Step 5Place your paper in the tray. For 8.5 by 11 inch (standard) paper make sure the 8.5 inch side will be fed into the printer.
  • Step 6Set the paper guide. This is the movable piece on the side of your paper tray. One side should move and the other should not. Move your paper so it touches the side that does not move, and slide the paper guide so it touches the other side. Some paper guides have markings so you can set it to the exact measurements if you know the size of your paper.
  • Step 7Set the paper thickness lever. Refer to your manual to determine which setting this lever should be at. Generally, standard paper does not need a different setting and special media like glossy photo paper or envelopes should use a thicker setting. You can usually access this lever the same way you access your ink cartridges.
  • Step 8Let your printer know what it is printing. If you are using a special media, then set the options before you print. Click “Properties” on the print dialog before you print something. From there, change your media type to whatever kind of paper you loaded.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Fan your paper back and forth before lining it up to load into your printer. This prevents static build up which is the leading cause of paper jams.
    • If your printer doesn’t feed the paper correctly at first, try making slight adjustments as it tries to feed to find the right spot.
    • Refer to your manual for in-depth paper loading instructions.
    • Many printers have a resume/cancel button. This is to be used when you need to load paper mid-print job.
    • Do not overload your printer.
    • Avoid non-standard media types such as loose leaf paper with holes or folded or wrinkled paper or anything with affixed stamps or stickers. These can jam your printer.
    hope this helps u
    please rate me...........................
    thak u for using fixya
    regards
    sivaranjini
    Dec 01, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Paper won't feed into printer. Always gets jammed
    you must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
    Jul 19, 2009 | Epson Stylus CX4800 All-In-One InkJet...
    I have an HP PSC 1510. I got a new computer with vista and it no longer does 2 sided printing. It used to have a pop up that caused the printing to pause allowing me to flip the paper and would print the...
    Wow! I have this same printer and I didn't even know it could do that. I don't know what's wrong with the machine, but to make 2-sided copies you can still just flip the paper, as long as you take the stack of blank paper out of the feed so it doesn't print your second side on a clean sheet.
    Mar 24, 2009 | HP PSC 1510 All-In-One InkJet Printer
    Copying problem
    could u plzz be more specific abt the line in the paper, i wish to know do u have the same issues if you are printing from the computer as well.
    Try the following steps...
    1) open the lid of the printer and clean the scanner glass
    2) scan a document to the computer and check if you are getting the line even on the scanned image, if yes then its an issue with the printer
    Apr 16, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Canon LASER SHOT LBP-2900 Printer Logo
    474 people viewed this question
    old marine
    old marine
