Water not working in our home. - Heating & Cooling
    Genius:
  • 1,036 Answers
Hi there!
Do your neighbours have water?
If yes, then you need to find the main supply pipe into your building.
Either it has been turned off by someone, or a safety valve has turned off.
Please reply with a little more information before rating.
Thank you.
Posted on Jun 18, 2008
How does it work
ntroduction to How Home Thermostats Work - How Home ...
home.howstuffworks.com/home-thermostat.htm
Introduction to How Home Thermostats Work - Thermostats are in every household, but have you ever wondered how they work? Learn about thermostats and ...
How do thermostats work? ' Bimetallic and gas bellows ...
www.explainthatstuff.com/thermostats.html
Jul 10, 2015 - So how does a thermostat work? Most things get bigger when they heat up and smaller when they cool down (water is a notable exception: it ...
Home Repair & Maintenance : How Does a Thermostat Work?
? 2:10
https://www.youtube.com/watch?v=b-WYdwlVy6s
Jan 27, 2012 - Uploaded by essortment
A basic thermostat works by tripping a switch that sends power to a furnace or air compressor to begin the ...
Jan 14, 2016 | Heating & Cooling
Tip
Eaton Home Heartbeat Water ShutOff Controller...
The Water Shut-Off Controller can be linked to HOMEheartbeat water sensors (HHBWATERSNSR) to automatically shut off your house's main water linein the event of a water leak. Simply place Water Sensors in high-riskareas for water damage. Then install your Water Shut-Off Controller onyour main water line and setup the unit to turn off if a Water Sensorbecomes wet. Then, when the icemaker malfunctions or the toiletoverflows your Water Sensor will become wet and your main water linewill close, minimizing the costly water damage.
NOTICE! This product requires installation of, and will only work with a HOMEheartbeat Ball Valve. Ball Valve installation may require professional plumbing assistance.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
on Jan 03, 2009 | Eaton Home Heartbeat Water Shut-Off...
Need to know if my Rheem 21V30-6N water heater is approved for use in mobile home
ONLY if the air intake is located on bottom so air can be drawn from under the mobile home
http://waterheatertimer.org/How-to-install-gas-water-heater.html#manufactured
-Or- if your water heater has power vent that draws air from outside, usually through side wall.
-Or- if your water heater is installed outside.... good for warm climates only
Otherwise ordinary store-bought water gas heater draws too much air from the space, and cannot work properly in a mobile home.
Gene
Sep 30, 2014 | Water Heaters
Nshow me how to wire Eaton 100amp disconnect
A disconnect is simply as it's called (a disconnect) it is connected directly to the power source and all circuits following depend on the disconnect to provide the connection to the main source. Like a main water line to a home ,there is always a main water value from the city located at your property which must be open to allow water to your home. The electrical disconnect works the same way with electricity from the provider to your home .
Sep 29, 2014 | Electrical Supplies
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
Aug 20, 2014 | Water Heaters
Just bought a new home and have a reliance heater. Some times the water is luke warm and some time it is like a boiler pipe. what should I look for or test
sounds like you have the heater set on its highest setting and its tripping the thermal protector. If that trips the water inside has to cool way down before it resets itself. Try setting the temp lower.
One more thing this time of year the water comming into the home is a lot colder this time of year and that makes the heater work harder and takes longer to heat the water. 40 degree water takes longer to heat than 65 degree water in the summer. This also means that it dont take much water cool the water in the water heater faster to luke warn.
If this is new home with a new water hater you might think about going tankless,then you have endless hot water and save money at the same time.
Jan 09, 2013 | Reliance & 30 Gal LP Gas Water Heater
Went away for 8 days, came home to no water in the toilet bowl or the tank. Put water in tank, and toilet bowl, flushed, water went away and still no water in tank or bowl. Help
Thanks for all your information. A neighbour came over and saw that it was the tank valve that had broken and so he went out to Home Depot, bought the part and it's now working. Yeah!!!
Dec 28, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Iphone home button not working due to water damage
If you are familiar with repairing electronincs I would recommend opening the unit up and inspecting the internal components of the home button and the corresponding logic board connecting point for corrosion.
You can get a new home button for about $6 on eBay. Just eBay search for iPhone Home Button.
Hope this helps, Please Rate Me!
Jul 09, 2009 | Apple iPhone 3G
My cuisenart 12 cup thermal coffee maker makes bad coffee. I can't return it as it was a fathers day gift. coffee always tastes bitter and burnt. at work we use the same coffee in a 20 dollar sunbeam...
The quality of the water is responsible for the flavor of the coffee. If you have had this coffee maker for a while it is probably coated with lime. Run a couple of cups of vinegar through it followed by a couple of pots of clear water. That will clean up your machine.
Once it is clean, try making a pot with bottled water, or water that you run through a water filtering pitcher.
You will be amazed at the differenct.
Jun 11, 2009 | Wega Mininova EPU Espresso Machine
Water doesn't stop
hi thanks for the question the problem seems to be a water valve especially a summer home sediment from well water gets stuck in the water valve or just a weak spring in the water valve i would replace the valve thanks the appliance doc
Aug 03, 2008 | Jenn-Air JCD2389G Side by Side...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
