Question about Samsung S860 Digital Camera
Hi i have samsung L201 camera. Its memory card is locked. How to unlock it? Anyone please help me to resolve this?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Nov 13, 2010
When I take pictures with my Samsung L201 there are horizontal lines on the picture when I look at them on the camera or computer
Greetings.
To resolve this problem you need to replace the ribbon cable inside the lens shutter.
For the unprepared person, unfamiliar with the repair of cameras - a difficult task. Such work can perform any repair.
For self-repair is necessary:
1 soldering iron, solder, flux
2 Tweezers
3 Screwdriver, small
4 Device for capacitor discharge flash
5 optics for if poor eyesight
Skills:
1 Reading the manual repair
2 The ability to solder
3 understanding of the mechanics of the lens (you must correctly parse and then properly assemble the mechanical part of the lens)
Flex -
Flex Samsung shutter L201 digital camera
Manual -
Samsung Digimax L201
Oct 03, 2014 | Samsung L200 Digital Camera
Card locked error on samsung es80
Turn off the camera and remove the memory card.Most cards have a lock slider at the side.You have to slide that button downwards/upwards to unlock it.Slide the memory card back into the camera.
Turn on the camera.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Samsung Cameras
How do you unlock card lock on camera?
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 13, 2011 | Samsung Cameras
I get a message saying 'card lock'. how can i solve it?
Some memory cards have a Write Protection switch on them.
To check this please remove the Memory card from the camera. Check if there is a "lock" switch on the left side.
Slide this switch to the "Unlocked" position, and reinsert the card into the camera.
This should resolve the issue and the error should go away.
In case the issue persists, it could mean the the write protect on this card was perhaps set by mistake while it was connected to the computer.
You will need to use the computer to cancel the read-only setting.
Please connect the card to your computer through the camera or a card reader and cancel the write protect on the card.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Sep 25, 2010 | Samsung Cameras
I have a samsung digital camera L201 Whilst taking
"format" completely erases the card. Why did you do that?
Jun 20, 2010 | Cameras
Card Locked message, how to unlock
Please turn off the camera remove the card turn on the camera once again then again turn it of insert the card and turn it on if the issue do not resolve then replace the memory card.
Feb 17, 2010 | Canon Cameras
How to unlock memory card
Remove the write protect lock off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Regards.
Aug 03, 2009 | Samsung Digimax S600 Digital Camera
Memory card locked
Hi..
To unlock your memory card you need to remove it first. Look at your memory card you can see them a small button square you need to slide it. After that insert it back to your camera, try to use what will happen.
Hope it may helpful for you!!
ICmanServer
Jul 31, 2009 | Samsung Digimax S600 Digital Camera
Hi My PRAKTICA DCZ 520 camera is saying CARD LOCKED when i switch it on, i cannot take photos, can anyone help me to unlock it please. Isabella
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jul 16, 2009 | Praktica DCZ5.0 Digital Camera
Memory card is locked
There is a small tab (like a very small hole with a sliding piece of plastic) on the corner of the memory card. Slide it to unlock it :)
Dec 17, 2007 | Samsung Digimax S800 Digital Camera
Samsung S860 Digital Camera Logo
207 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
