Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
I have try several solution on my bb 900 but still yet still blinking red light and not loading o.s pls what can i doe
My HBS-900 headsets have a blinking red and blue light that blinks when it's on and off, it won't pair with anything, and when I put it on charge it blinks red and blue
Usually this means there may be too many Bluetooth devices in range to connect to and cannot connect so the blue and red flashing lights indicate an error. A second possibility is that the device is broken. This might sound strange but sometimes several sharp firm raps to the side with the charger port and lights along with a few power cycles often snaps it out of error and back into operation. Good luck.
Dec 28, 2016 | Radio Communications
Hi there, My washing machine is hotpoint WTL500
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Aug 11, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
My blackberry 9000 wont open when i plug charge show the red light iam tired for that i quit battery and wait ahours i pluged charge usb again that wont open plis helppp
I am unsure of exactly what you were saying. I will assume that you mean that your BB9000 is never turning on and that the red light is blinking. This is a common occurrence when the firmware becomes corrupted. Ideally you will have been backing up your data for situations like this using the BB desktop manager. If you have been then you know how to restore the information then. The real problem is the firmware.
A blank screen with a blinking red light is a bit of a bear to deal with. You have to have the BB Desktop manager installed on a computer. You also need to have the most recent firmware for that particular device loaded into the desktop manager. Both of these programs will be available through your cellular provider. When both are installed you need to plug the device in and run the application loader. Tell it to overwrite existing data if it asks and just let it go to town. This process may take up to 45 minutes to do and the phone will look like it is hanging up most of the time but have faith. If the process errors out or does not work there is another trick. Follow the steps above but do it with the battery out. As soon as the desktop manager says that it is 'loading application data' then put the battery back in and then wait. Sometimes the firmware will refuse the connection to the computer if it is in a damaged state and removing the battery keeps it from refusing the connection. The battery has to be put back in before the application loader finishes so the firmware can initialize.
Mar 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
BB Bold 9000 wont turn on - red light is flashing. Its been charing for several hours now and still will not turn on. I've taken the battery out and put it back in, then charge it some more...still...
I' really sorry to tell you, but looks like your phone's logic board is out of work! It happened if mine BB 9000 two moths after the warranty expired! Took to a technician and I was told to replace the logic board! It was happen like this (http://www.youtube.com/watch?v=MGSRQb1Qb1Y) before it get out of order forever! Hope I have helped you! Just to you to know I tried just about everything that is on the net, and nothing worked!
Apr 20, 2010 | RIM BlackBerry Bold 9000 Smartphone
Wen i power switch my PS3 red light comes on then wen i pressed down once to get in on beeps once, then green light comes on for a second then yellow light to a steady BLINKING RED LIGHT!!! And does NOT...
This is called the yellow light of death. Cause is sever heat damage to the internal components. Either send it in for repair or replace. Sorry about this but the truth is brutal.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
My screen wont cut on and its giving me a red light that blinks twice over and over again
Try this:
1. Unplug BB from PC.
2. Launch the Application Loader like you were going to install something.
3. While the app loader is attempting to connect to the BB, plug the USB cable into the BB.
Jul 11, 2009 | RIM BlackBerry 8700g Smartphone
BlackBerry 8310 red blinking led indicator (it fell in water)
If your BlackBerry gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Jun 22, 2009 | RIM BlackBerry Pearl Smartphone
I try to turn on camera and first I get green light then red blin
i try to turn the camera...but it seems that hangup,,,,the lights green it blinks blinks,,,,and theres a circle on scren.....i have lotsof pic there that is very important for school...was it gone?waht can i do so that my pic wont lost?pls help..
Apr 10, 2009 | Cameras
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
188 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
