Question about LG Dishwashers
LG LD-A2T2 Dishwasher returns Error code E1
My dishwasher commences the cycle and fills perfectly but then errors with code E1 and empties itself. There are no leaks and has been working fine for months.
I did change the inlet hose some months back when it sprung a leak but has been working OK since. There was no error with the leak months back but a huge puddle of water on the floor.
What are the possible causes and steps to rectify?
  • 2 more comments
  • Toska Jun 25, 2008
    Definately not siphoning out as it is full of water when the E1 code come up and nothing has changed in the physical set-up.
    The outlet hose goes to the waste water drain that is a minimum of 40" in height. The error occurs at the end of the fill cycle.
    Looks like I need to get a technician in as I am tired of washing by hand.
  • Toska Jul 07, 2008
    The drain pumps comes on when the dishwasher is started and stops whilst it is filling. At the end of the fill, it stalls for about 30 seconds then errors with E1 and the drain pump comes on and empties the dishwasher. Is the float switch under a panel - I cannot see it nor do I know what I'm looking for.
  • Toska Jul 10, 2008
    Thanks. I thought as much. I'll pull it apart on the weekend. Are there any other parts to be removed after the panel is taken off? Is the float visible or will I need to disensemble more of the plastic components?
  • Toska Jul 13, 2008
    Could not see any problems with the float - time to get an expert in.
    Thanks any way.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
EI is an error to do with your drain. Check your drain hook up. You should have a loop out side the unit, it should be a minimum 40in in height, or put in a air break. What I believe is happening is your unit is siphoning out. Fix this and you will be able to stop washing the dishes by hand.
Sgt 48
Posted on Jun 19, 2008
  • Andrew Lauder Jun 25, 2008
    On the left side of the unit when looking at it, you have a float switch, maybe it is stuck up. Do you hear the drain pump running constantly?
    Sgt 48
  • Andrew Lauder Jul 07, 2008
    The float is located on the left side of the unit. To get to it you have to take off the left side panel.
    Sgt 48
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
I have a LG Diswasher LD 2050 with a trouble Code E1. The manual says "Water leakage in hose connection" "water is leak by damage" Ihave check and everything is Okay. It let water in and when it start...
The most common problem on an LG dishwasher when error code E1 is reported but there is no actual leak found is the problem of a natural syphon being created by improper installation of the dishwasher. Pretty easy to fix:  Either add an Air Gap valve (available at any hardware store for almost free) or follow the drain hose from the dishwasher to the drain. Raise the hose and attach the hose to the up onto the bottom of the countertop. Adding that "rise" eliminates the possibility for the syphon effect to drain the dishwasher before the drain cycle begins.
If the hose ever fall back down, the problem will return immediately.  Adding the Air Gap valve is harder but is far more permanent (and complies with construction codes that really should not be ignored.)
Apr 17, 2009 | LG 24 in. LD-12BW5 Free-standing...
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
"E 1 code error
E1 is a drain error. On the unit prior to mar 07 LG had a problem with wires breaking in the door. Turn off power supply, remove door panel and look for wires stuck in the insulation. Check continuity of the wires, if broken, splice and tape. Place insulation between black insulation and wires to prevent reoccurence.
Sgt 48
May 24, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
559 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
