Question about Home
I have a remington the striker blind model 10001 I don't know how to take it down
Extremely weak motor model 108526-01 remington
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Feb 12, 2014 | Remington Garden
Old Remington SL4 Automatic Oiler
Found a website with all the equivilant homelite XL12 illustrated parts lists. You may need to look down the list to find the exact match.
Jul 27, 2013 | Remington Garden
I took my father in law's Remington 1.25hp
PRAY! NEVER BORROW a father in laws equipment!!!! Let it sit for a short time and cool down and then see if it will start. I would also check the air filter and make sure that it isn't plugged!
Jun 24, 2011 | Remington Garden
My new Remington R3130 will only work when plugged in. it has never held a charge. i don't see anywhere that batteries would go. please help
Model R-3130 is a cord only model. It does not have batteries to charge. The rechargeable models are R-4130, R-5130, R-6130 and R-7130
May 05, 2011 | Remington R3130 Electric Shaver
Oven door won't stay closed
You don't state the exact model but on every oven I've ever fixed this problem on it's a broken door striker catch. Depending on your model, the catch will either be in the oven door or in the oven body; usually they're straightforward to replace but on older ovens spares can be almost as rare as dodo ****. Usually what breaks is a hardened tempered metal spring, so when they're not available as spares I can usually visit a local spring making company and get someone to make one up as a one-off using the fragments of the old one as a pattern. After the catch has been replaced the striker itself (usually a specially shaped pin) may need to be adjusted to engage correctly once more. Undoing the lock nut and screwing it in and out adjusts the depth, and is done after the striker catch has been adjusted side to side or up and down to meet the centre of the striker.
Mar 04, 2010 | Imperial Ovens
Where can I get a manual or take down instructions for a Remington model 11.
The Remington model 11 and the Browning Auto 5 are pretty dang similar. Both made during the same time. The take Down is very Similar.
Here is a link to the take down/user manual for the Browning Auto 5.
LINK
However, if that makes you uncomfortable, Instructions are available in the Gun Digest Book of Firearms Assembly/Disassembly Part V: Shotguns for the Remington Model 11.
Hope this helps.
Oct 15, 2009 | Remington Sport & Outdoor - Others
Remove range cover on remington chainsaw Model LD4018Aw
this web site has partsbreak downs.................http://www.masterparts.net/ hope this hepls,let me know
Jun 01, 2009 | Remington Electric Chain Saw
Home Logo
293 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
