Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
The lever wont open the bottom that empties the canister. Canister is full and I have no way to empty. Please help. Thank you.
SOURCE: T2100 S Ladybug Canister Steam Cleaner
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Posted on Dec 16, 2008
rickzilla
  • 706 Answers
SOURCE: my central kenmore vacuum wont suction
Hello hdd85,
I think you answered your own question when you verified that all the vacuum outlets have vacuum on them and then after you hook up tyhe vac hose, you fail to get vacuum at the other end. I would say that based on your problem description, you have an obstruction in the hose. You may have afriend with an air compressor that you can try forcing air in one end to free up the clog but if that doesn't work, do you know anyone with a wet/dry utility vac that you can try using the vacuum or exaust side to free the hose up ? Lastly, if you know an electrician, they normally have 'snakes' used to fish wires thru wall cavities... If careful, that might get the clog out.. Hope that gives you soem ideas on how to resolve,,,,
Regards,
Rick
Posted on Jan 26, 2009
odiebugs
  • 949 Answers
SOURCE: how do I open the Sharkplus canister vacuum? I have no manual.
Where the hose plugs into the canister,just above it should be a button that you push in to lift the top back. You did not put what the model # was,so its not easy to find things without the model #.
Below is the manual for model# ep3005t, but once your at the site you can get the right one.
The manual is a pdf file, most all are,so you need adobe reader to view the manual,also I am putting the link for the reader,it is free. Ifyou click on the links I post and it does not take you too the site just
copy the link and put it in your browser.Hope this helped you.
http://www.sharkvac.com/productDetails.aspx?ProdID=0xbTZnOD3Iw%3d
http://get.adobe.com/reader/
Adobe reader should work on xp and vista.
Posted on Mar 24, 2009
  • 78 Answers
SOURCE: I can not open my dyson canister to empty it
if you take the bin off of the unit and try to pull the release trigger and it feel vry lose then you will find that the connector rod inside the cyclone has broken you will need to replace the cyclone unit as the rod comes complete with the cyclone
Posted on Oct 30, 2009
SOURCE: Canister problem
i cant get mine to open?
Posted on Nov 30, 2009
How do you empty the dirt from bagless compartment?
some have a thermos like can you press a button on top and it should come off. if not look for a sliding thing at the bottom of the canister.if this still doesnt help please email me a photo of it at Mmonmon343@gmail.com. thank you and have a nice day
Oct 12, 2015 | Dirt Devil MO82500 Bagless Canister Vacuum
I cleaned the filter and emptied out the canister from the bottom and now the dirt comes out on my filter and not in the canister?
The first place the "dirty" air enters is the top chamber of the canister where it traps the bigger stuff.
The canister has two clean-out doors so make sure you open them both (top and bottom) or you could have problems.
Nice thing about the Shark as it has a number of clean-out points starting at the base of the hose where it enters the bottom of the vac. to the beater brush (on the bottom of just behind the brush assembly). Good luck!
Mar 16, 2015 | Shark Navigator Bagless Upright Vacuum
How do you empty the dirt out of it
The plastic dirt holder should have a lever that opens the canister.Should come right out with a slight pull.empty contents into the trash.
Oct 21, 2010 | Dirt Devil Easy Lite Quick Vacuum
Hi, im hoovering my mothers house whilst she is away, using a vitesse pet lover, but now the cylinder is full and i can work out how to open it so i can empty it. thanks
Lift the catch where the canister lid joins the handle, then pull the whole assembly away from the handle.  Take the assembly to wherever you want to empty it, then press the button at the bottom front of the canister.  The bottom swings down and the muck falls out.  In the ideal world, you will then take the lid off by twisting it slightly anti-clockwise (you'll see the "lock" and "open" markings on the canister rim), remove the pleated filter (again by twisting anti-clockwise), give it a good shake and then brush between the pleats.  Reverse this process to put it back together, and away you go again!
I hope this helps. Any more questions, just ask. Please remember to rate my response, thank you.
Apr 14, 2009 | Electrolux Vacuums
Oct 20, 2008 | Vapor T 2200S LadyBug Canister Steam...
Dirt canister lid is stuck on
push it back in till you hear it click.pres the button and hold and pull the dirt cup at the same time.please leave feedback
Oct 07, 2008 | Dirt Devil Featherlite Bagless Vacuum...
Round filter clogs often
The Flange in question is about one inch tall and and approx 4 inches circular ..... When you pull the canister (container to empty) off and empty the contents in the trash .... some of us tap it to get the excess out or off the sides ..... That Flange is the rubber piece attached to the bottom of the darker gray cylinder inside the canister you are emptying. When you tap the canister or after dumping it numerous times that flange can work itself (slide) up the darker gray cylinder ...... it needs to be slid downward and overlap the bottom when you close the canister from dumping it. You can remove the flange and see the grooves .... replace it back on with it hanging off a little to allow for overlap. That should decrease the amount of excess being trapped in the filter. Hope this helps.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Canister problem
If it won't latch after cleaning the latch and making sure that everything is seated well, get in touch with Dyson, they're great about making things right with their vacuums.
Sep 18, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
99 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
