Question about Konica Minolta magicolor 2300DL Laser Printer
Replacing Toner Not sure how to replace the black toner on the printer. When door opens its either the blue or pink toner in view. How do replace the black toner???
  • kimm1 Jun 18, 2008
    It's done via the printers internal menu system:
    On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
    Champion:
  • 214 Answers
This operation can be done a little faster with a little help of screwdriver. but of course this is the right way to do it, but it takes a long time, for me.
Posted on Jul 02, 2008
I replaced a black toner after that the is only displaying printing cool down mode and not printing help to know the problem
if the problem started only after replacing the toner, u can look if there is something went into the printer while replacing the toner. open the door & look carefully for any object/dust inside the printer.
may be there may be damage done during replacing the toner. try to replace a new toner & watch the results. printing cool down mode indicates that fuser assembly which is inside of printer is hot & will take time to cool down. there may be a problem in that fuser assembly.
Sep 13, 2011 | HP LaserJet CP1518 Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
How do i replace the toner?
Open the white door
pull bypass door towards you
move the blue lever towards you
slide lever to the side ,lift out the old cartridge
pull tape on new toner
snap in new toner firmly
push blue lever forward
close doors
Oct 27, 2009 | Kyocera Copystar CS-1820 Black and White...
How do I replace the waste toner?
The waste toner bottle is just a bottle that the old unused toner falls into. It is located on the right side of your printer. Open the right side door, and the waste toner bottle (which is wide and flat) is in plain view taking up the bottom half of view. It has a sliding lock on top. Slide the lock to 'unlock' and remove it. Replacing it is easy - just reverse and make sure to lock.
Jul 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Oct 02, 2008 | Dell 3010cn Laser Printer
Replacing black toner cartrige
if you have a status monitor installed, then you can choose from there replace bk toner and printer will turn the right toner in right place if not, then open front door remove waste toner box, locate about 1 cm usually crey ring knob, in left upper position, use screwdriver or something to push it then you can easily rotate the toner rack to the left, and pick a needed color.
Jun 23, 2008 | Konica Minolta magicolor 2300DL Laser...
Page is black
NO Try to remove the toner and insert it again and make sure the door is locked properly
Apr 22, 2008 | HP LaserJet 2840 Printer
Black Toner Cartridge
Open the front door, look to the left for the interlock, insert a screw driver or similar into lock.
Carousel can now be rotated by hand.
I believe you can also rotate the carousel to a particular toner via the panel and driver.
Apr 09, 2008 | Epson Aculaser C1100 Printer
Dell 1710n printer problem...
Try resetting the error lights with a drum reset. With the power on and cartridge door open, press and hold the Cancel button until all lights flash in sequence. Release the button and close the door.
Feb 28, 2008 | Dell 1710n Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
