Nokia 6500 Slide Cellular Phone Logo
Posted on Nov 13, 2010
When i turn phone on it shows the nokia logo then screen goes white then switches off
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Nov 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
1501
Points
45
Problem with your software other wise reset the phone
2helpful
2answers
Nokkia 5130 -screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off...
nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
4helpful
3answers
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
1helpful
Hii My Nokia 5130 Express Music phone doesnt start up. It shows "test mode" on plugging the charger. Even otherwise, on starting the phone the Nokia logo appears ten the screen goes white and switches...
please format your phone using first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
Oct 20, 2010 • Cell Phones
2helpful
2answers
The phone does not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times before switching off.
your phone got deads its happens many times when firmware is not properly updated,try to update your phone firmware but be care or send it to nokia centre
Nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
Try pulling the batter off of it and have someone test the battery for voltage and amperage. then try cleaning all the connectors and replace the battery. I had a phone that randomly dies and it was because the power connection was dirty.
15helpful
2answers
Nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
N70 showing white screen with nokia logo only
proceed to THEMES and then select w/c theme you prefer .
White screen
This is the problem with corrupted phone software you need to reinstall the phone software get it done by the company if it still under warranty or if its out of warranty get it done in local mobile service center..
Good luck..
4helpful
2answers
Phone restarts on its own
I tried to switch on my cell with the data cable already attached.It kept on beeping on my pc but cel did not switch on.I detached the cord and switched on my cel.It showed the nokia logo and kept switchin on and off.Later i removed the battery,replaced it back and switched it on.And BANG!!! After 5 minz it switched on!!!!!!!!
2helpful
2answers
Nokia 7610 white screen
Format Your Phone By following Methods:- 1) Enter *#7370# & press the send key as this will do the Software reformat if the problem still persist try method below 2) Turn off ur phone....Hold Green key, * key & 3 at the same time turn on the phone...the Total format of phone Just make sure you're hold the three keys down firmly during startup. Don't let go until you see "Formatting ..."
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
