Question about HP Officejet 4215v All-in-One Printer
I cannot get the scanner option to install onto my new Gateway. It tells me there is no scanner option and to install the software, which I do not have.
    Sergeant:
  • 337 Answers
Goto www.support.hp.com and look for the correct drivers for your computer, make sure to select the correct operating system with the version i.e- 32bit or 64bit. Install the driver and that should do the trick.
Thanks. If this was helpful, then kindly rate me.
Posted on Nov 13, 2010
Epson v300
Make sure you have Adobe acrobat or similar installed so that you have PDF available on the PC. It may also be in the software for the Epson. I had a scanner a few years ago whose software excluded PDF and I ended up installing new software of a generic printer / scanner to use Adobe PDF
Jun 07, 2012 | Epson Perfection V300 Film Flatbed Scanner
I have a Canoscan 4200F scanner. I have purchased a new computer with windows 7. The system tells me that my version is incompatible with Windows 7. What do I have to do to fix the problem?
you have to get a new driver for Win 7 probable the software was designed for Vista; go here there you can download the new driver. after you install it Windows 7 has the option to use the scanner from there you may have to get a new software to edit your images but you get the scanning features on Win7
if it works for you, don't forget to rate me
thx
May 26, 2010 | Arcsoft PhotoImpression® 6 Full Version...
I got a new computer (Gateway) and I installed the software for my canon scanner and whenever I try to open it I get a box that says ''insufficient memory.'' How can I fix this?
Since you're getting this error, I believe that the software is not completely installed. To fix it:
* Uninstall the scanner software.
* Check the target location (if you're going to install it in drive C: or D: or any drive letters). Make sure that the location has enough memory space to accommodate the file size of the scanner software.
* Delete some unnecessary files.
* Re-install the scanner software.
This should fix the problem. Have a great day!
Sep 13, 2009 | Canon Office Equipment & Supplies
I wanted to download the software for the Pixma MP830 to my new computer I purchased, but I got the error message "the scanner driver supported by this software is not installed. Install it and then...
You have two options:
1) Use the installation disc that came with the printer and install the software onto your new computer using that disc.
2) Go to Canon's website by clicking here and download the correct driver and install it. You will have to know which operating system your new computer has to get the correct driver.
I hope this helps.
Aug 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Lines in pictures
Typically when this happens you either need to go into the printer properties and align the print head or if your printer is a modle where the print head in not attached to the ink you need to get a new print head. to be able to tell if your print head is attache just look at the bottom of the cartridge if you see a metal looking part then you have a bult on print head but if you see ink then your print head is built into your printer.
In most cases the print head is more expensive than a new printer so it is not worth replacing. As far as the scanner issue look under your start menu for an option that says HP under that see if there are any programs called setup or scanner if you do not see it there check in the row of icons that are to the left of the clock on your task bar, place the mouse over them one by one and you will get a message that telle you what they are. If you find one for the HP printer/scanner right click on it and see what your options are. This program will allow you to set up yous scanner. Most HP scanners have to have some kind of program running in the task bar in order for the buttons to work.
If you do not see any of these things I recommend that you re install the software that came with your scanner
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
I am trying to load the software from my older scanner onto my gateway computer, that now has Windows XP and the software only uses Windows 98
HI YOU NEED TO RIGHT CLICK ON THE SETUP FILE THEN PROP AND THEN COMPATABILITY THEN CLICK BOX AND CHANGE IT TO 98  THEN APPLY THEN INSTALL IT
Dec 04, 2008 | Computers & Internet
Just installed software on my new C8180 All-in-One and scanning is a problem. Error messages keep telling me to remove software and to reinstall etc... Re-start etc.... I have done all these things but the...
You may have to temporarily disable your FIREWALL, ANTI-VIRUS, PHISHING FILTER, etc to get the software to install correctly. Also, when installing the software, do not use the DEFAULT OPTIONS. If there is an ADVANCED setting for the scanner, select that, and see if you can configure it for your requirements.
Aug 10, 2008 | HP Office Equipment & Supplies
Installing software for new canon digital camera
Apparently Windows Vista does not require the software and worked without installing it. Regards Trish
Jul 28, 2008 | Canon COLOR IMAGE SCANNER
HP Officejet 4215v All-in-One Printer Logo
129 people viewed this question
Seeker5211
Seeker5211
