Question about Dell Latitude D430 Notebook
No display on power, 2 lights blinking after a 15 sec or so, it shuts down automatically. Can anyone help thanks
  • Linson Chan
    Linson Chan Nov 13, 2010
    OH MY!!! ARE YOU EVEN READING THE POST!
  • Linson Chan
    already got this problem fix.
    Sergeant:
  • 337 Answers
Its a no post issue. The computer must be making some beep sounds, disconnect everything thing from the computer except for keyboard, mouse, power and monitor. then try, if still doesn't work then you are looking at an internal hardware failure.
Thanks. If this was helpful, then kindly rate me.
Posted on Nov 13, 2010
How do i fix/repair 6 blinks sony bravia LCD KLV-46Z450A & shutting down problem?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 20, 2015 | Sony Televison & Video
Can't turn on Dell Inspiron 1501
dear sir , acutully your dell laptop is in hibernation mode, and is not coming back
you can try following:
1. remove batter plug directly and try to switch it on without battry.
or
2.press power switch for 13 sec continusly and once it shuts down , switch on it again
this will definatly help you
thanks
Dec 11, 2007 | Computers & Internet
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
May 11, 2009 | Sharp LC-13AV1U Television
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
Power and sound turn off after 15 minutes
Is the red light blinking in the front of the tv. Counnt the blink sequence then I can give you more info.
Oct 05, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Dell Latitude D430 Notebook Logo
187 people viewed this question
Alun Cox
