Slow connection from client win98se to winxp to cable modem with home networking
    Champion:
  • 214 Answers
try delete cookies and temparary internet files.
also clean the temp directory inside the windows dir.
Please don't forget to rate or accept the solution
Posted on Jun 18, 2008
What kinds of ADSL access way divided into?
ADSL access namely use parallel twisted-pair cable access user home, using M connected PC, whether it's special line, virtual, routing, all leave twisted-pair and MODEM.White said again is to run the business broadband signal through the circuit access user home, using computer dial-up MODEM connection.As for the access network equipment, PON, connection cable trunk, wiring, equal twisted-pair, client PC, router, such as TV all need to slowly in the actual operation experience.
Oct 30, 2015 | Computers & Internet
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
Hi Currently i am using internet Type: Broadband provided by Local Cable operator Modem:Motorola SB5101i Connection type: PPPoE [with username/password] Using with: Dell inspiron15 Laptop Location:...
There is a configuration facility included with the modem that you should be able to access to help troubleshoot the connection.
The Cable Modem has three active interfaces, the HFC, the Ethernet and the USB and each
interface has both a MAC and an IP address associated with it. When operating normally it is the
IP address of the HFC interface that is used for diagnostic access to the modem. However the IP
address associated with the Ethernet interface is always available to the client side network,
unless it has been disabled by management command. This means that a PC on the client side
can access the WEB pages within the modem using the reserved address 192.168.100.1. This is
a non-routed address so it cannot be reached from the Internet (routed) side of the network
The SB5100 family of modems contain an internal DHCP server, which is active until the modem
registers with the CMTS. In the case of a problem that prevents the modem from completing its
registration, the modem can still give an IP address to the client PC to enable diagnostics access.
This address is given with a very short lease (around 10 seconds) so that as soon as the
registration does complete the client PC obtains its proper IP address from the core network
DHCP server.
Mar 15, 2017 | Arris SURFboard® SB5101 Cable Modem
My internet connection is slow. wireless home network setup connected to adsl.
is it as slow as when you connect it from the router(not the modem) to your pc with a wire instead of wireless? if so its bc adsl is slow in nature and you may need a filter adapter going into your MODEM first
Mar 25, 2011 | Linksys Wireless-G WRT54GL Router
Cable modum not detecting PC activity????
Unplug the power from your cable modem. Turn off your computer. Make sure there is a network or usb cable connected to the computer from your cable modem and they are connected properly at both ends (if usb use the back ports on the computer).
Plug the power back into the cable modem and wait 1 minute. Turn on your computer. Check connectivity by trying the Internet.
If you still do not have connectivity, try these things in this order:
1. Update the drivers for your network card through your computer/motherboards manufactuar website.
2. Replace the network or usb cable and try again.
3. Contact your cable provider to make sure they can see your cable modem on the network.
If you need to connect via PPPOE, usually this only applies to some DSL clients. It is reccomended to use the install disk that came with your modem so you can set up your username and password correctly to connect. If you need additional information on this, contact your ISP for configurations.
Have fun.
Jan 29, 2010 | Computers & Internet
How to remote client winxp by using windows 2003 server with ISA2004 server
you need to configure a policy in ISA to allow 3389 port for RDP.
you can then connect to winxp client using mstsc utility.
Nov 12, 2009 | Microsoft ISA Server 2004 (e84-00526) for...
I have a DGL-4100 behind a Linksys DSL router 2 networks don't.
zSB(3,3) Installing a Two Router Network Installing a router to work as the second one on a home network requires special configuration. Do the following on the second router to ensure it (and the devices attached) function properly:
    1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
    2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
    3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Oct 10, 2009 | Computers & Internet
Can't connect to AT&T VPN
as you told me that all the ports are open so in that case you can get in touch with your ISP and ask them to enable IPPASSTHROUGH on your office laptop.
Jan 17, 2009 | Zoom ComStar 56K 2818 Modem
Moto Surfboard SBG900 and VPN Client = SLOW
Please see the specicification, also check with you company
IT Admin, to release it to the Max speed or to check the
net work cable, may be too long, also Test the cable with a Data Test meter and conform the data quality. Or change the port from main router.
Otherwise change the whole networking router.
Regards
Nov 15, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Computers & Internet Logo
David Payne
David Payne
