Question about PNY 8GB USB 2.0 Flash Drive - Blue/Black
Wine i want to open my usb cam this message the disk in drive G is not formatted Do you want to farmat it now win i priss the yes butten agin came another messige you dont have sufficient rights to per form this obration .
    Brigadier General:
  • 10,406 Answers
Move the USB memory-stick to a different computer, preferably one "privately" owned,
and then retry the FORMAT operation.
Posted on Nov 13, 2010
If i try to farmat my usb stick it tells me that windows can not formate it
It may have a password. Open the storage space by providing the required password, then you should be able to format it.
Oct 01, 2013 | Verbatim ® Store `n` Go USB Flash Drive,...
My transcend micro sd card can't be farmatted? pls help me
click start click on my computer you should see your transcend usb drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your transcend drive select format
hope this helps
May 24, 2012 | SanDisk 2GB microSD Memory Card
I can't find my Hitachi 250 external HDD in my computer.Although i can see it on the Devices and Printers,but also there is no option of open it or do anything on it. Goodluck
Your external hard drive has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click Administrative Tools.
4. Double-click Computer Management.
5. Select Disk Management under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hdd.
Thanks for using FixYa.
Mar 09, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Doesnt want to be read by the computer it lights up and instals drivers doesnt show up in my computer
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
Good luck and thanks for using FixYa.
Dec 29, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Windows 7 does not recognized it
Dec 27, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Message "the disk in a destination drive is full"\...
Right Click USB > Properties > Hardware TAB > find your USB or general usb flash disk usb device , Double Click it > Go Policies TAB > Optimize for perfromance
then Click Yes ,
don't press the emergency restart
then format it ,
right click > format file system , choose NTFS
then wait ,,
copy and paste
May 20, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How to recover flashdrive transcened 4gb v30, it can detect but i can't open?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Oct 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Computer error problem
http://www.fixya.com/PostAnswer.aspx?thid=2692939
drea_mike67 on Jul 31, 2009
a message saying windows-no dis exception processing message c0000013 parameters 75b6bf9c 4 75b6bf9c 75b6bf9c then it says cancel try agin contunue and i push one and it just keeps coming back constantly.
Friday, July 31, 2009
Hello drea_mike67,
There may be any number of storage device faults causing the no disk exception error message. For instance, a usb device may have been removed without choosing the 'safely remove hardware' option. If that's the case then reconnect the usb device and choose 'safely remove hardware' (bottom right hand corner of your PC screen), and then remove the USB device.
If the error message still comes up then try using the device manager in the windows control panel like this:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
In the Control Panel, do the following:
•Select System
•Select the Hardware tab
•Select Device Manager
•Look for disk drives or other drives that are not used or recognized...
•Right click the device(s) and select uninstall
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 31, 2009 | HP Computers & Internet
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Jan 13, 2009 | Electronics - Others
PNY 8GB USB 2.0 Flash Drive - Blue/Black Logo
61 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
