Question about AMD IC Power CN5560 Laptop
Ic mobile sempron booting but not reading master drive.
    Habit-Forming:
  • 89 Answers
Check the BIOS setting for the master drive or the boot drive sequence. check if the HDD cables are intact. there could also be possibility of a corrupt HDD
Posted on Jan 03, 2014
I've inherited this ic power nc5560 notebook at work. several people have had the thing before I got it and it's so loaded down with **** (apps, files and other garbage) that the things is...
Typically each hardware manufacturer has a key stroke to hit during power on that will take you a system recovery mode (basically reload the operating system that was loaded when sold). The hard drive usually will have a second partition that is not visible inside Windows. This partition holds the "image" of the base operating system. If anyone deleted this partition you cannot factory reset without install CDs.
Alternative: Try booting into safe mode by hitting F8 during boot (this will not load all the garbage apps). Once in safe mode uninstall as many application that you do not need, then boot windows normally and run disk defrag a few time to help improve performance. Hope this helps.
May 19, 2011 | Computers & Internet
My china mobile nktel A200 not reading memory card
naktel a200 memory card not supported solve this problim
Sep 18, 2010 | Cell Phones
Weird problem. CPU recognizes the sata, windows will not boot, recycles to start-up over and over. Tried with xp disc to repair, came back as "no hard drive listed. If I changer driver from master to slave...
It is possible that Bios/Cmos battery is not maintaining its charge. You might want to pull the cmos battery & check its voltage with a volt meter. It should retain 3volt DC. If it reads lower than 3v replace the battery. Once replaced you will need to reset all bios settings. If the battery checks out ok than continue.
The soulation to your problem lies within the Bios not your hard disk drive. Set the jumper you moved to slave back to master. Re-connect the SATA data & power connector to the motherboard. Boot up your PC & start pressing the Delete key on your keyboard every two seconds untill the Bios menu opends. (See page 2-14 section 2.3) in your manual.
You can not use your mouse while in the bios. Read page 2-12, section 2.2.1). This will explain how to move about while in the bios. Once the Bios opends you will be at the main menu. If your SATA drive is correctly connected you will see its model number listed there.
If you have two SATA drives connected you should see both. Take note of which is the master SATA1 drive. All SATA drives run as master drives. While in the Bios, SATA drives are shown from top to bottom. First /top drive will be the master drive. Next drive down is considered as slave.
Than open (OnChip SATA controller). Set this to [Native Mode] or to [SATA]. See page 2-16, section 2.3.5
Than open Boot. See page 2-30, section 2.6, Open Boot Device Priority section 2.6.1 Here is where you need to set the boot order.
(The boot order is not set correctly & this is why windows does not see your hard disk drive & showed the message "No hard drive listed").
If you have a floppy disk drive connected to the system set it as,
[1st Boot device]
Change 2nd Boot Device to [CD-ROM]
If you have two CD/DVD-ROM drives in your system make sure you set the Master CD/DVD-ROM here & not the slave CD/DVD-ROM drive.
3rd Boot Device should be the primary [SATA1 drive], connected to SATA1 port on the motherboard. See page 2-30 section 2.6.2
The drive with windows installed shoud be listed as 1st.
Save your changes & exit the bios. Your system will auto re-start.
If you had a working operating system on the drive it should load.
If you need the motherboard manual or drivers you can download them from Asus web site link below;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
Cheers!
If you are still having troubles, post your question here.
Mike
Sep 24, 2009 | ASUS P5S800-VM Motherboard
Installed new hard drive -
make sure you have set it to the appropriate setting eg: master or slave, it is at the front of your drive, you can not have 2 masters or slaves on the same ide cable, it has to be 1x master +1x slave
Dec 22, 2008 | EliteGroup ECS Motherboard MB K7VTA3...
Maxtor One Touch III 320GB
THE PROBLEM IS MASTER AND SLAVE CONFIGURATION .. MAKE YOUR BACK UP HD A SLAVE IT MAY BE A MASTER NOW..
AND IF ITS A MASTER MAKE IT SLAVE
IF IT STILL DOESNT WORK THE CONTROLLER IC ON MOTHER BOARD CAN BE FAULTY.
Jul 28, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Computer does not see hard drive or cd rom
Use separate cable for both the hard drive.
Make master to the one which is bootable,restart your system and just check bios setting whether both the hard disk are detected or not..also under boot device check first boot drive is hard drive which is master and bootable..
Jul 21, 2008 | Dell OptiPlex GX260 PC Desktop
Processor
try to configure it in the bios manualy , and set it the right rating 1.8 Ghz so that i will run faster.
or use this: http://www.freshdevices.com/overclock.html
Jan 25, 2008 | Computers & Internet
I Can't Install Windows XP Operating System on my AMD Sempron Computer
cheak ram clean disk ? try one ram do partion on hard drive del it then make new one then slow formatt then install ok and update call it in
Jan 18, 2008 | AMD Sempron 2400+, 1.667 GHz (sda2400box)...
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Computers & Internet Logo
21 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
