Question about Panasonic Televison & Video
Led flashing 3 times,
Hi
I have a rear projection tv that turns itself off as soon as you turn it on and the led flashes 3 times
From what i understand it seems like the convergence ics need replacing and im not sure if this model uses the stk392-110 ic.
The repairer wants to charge me $1200 to fix the problem, and tells me it is the power supply, but this doesnt fit with the led flashing 3 times
Is there any other idea to what this problem could be other than the ic's
  • trackie26 Jun 18, 2008
    I forgot to add that this is a panasonic tx 47p950a rear projection tv
  • 4,234 Answers
Please post the make and model as each has their own blink code. I can provide more detailed info once I know the make and model.
Thanks,
Dan
Posted on Jun 18, 2008
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
No picture on tv all three lights flashing on front of tv.
Three blinking LEDs mean lamp may be defective replace the lamp.
May 25, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic model# PT-47WX547 is not working
how many times does the LED blink ? Thats a error code.
Jun 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Television won't turn on
If its a DLP tv chances are the bulb went out, double check with the manufacturer before getting as they are not cheap, around the $250 range.
Oct 26, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Oct 22, 2007 | Sony KP-51HW40 51" Rear Projection...
TV turns off aftering powering up. red LED flashes 3 times.
3 red blinks means th lamp door in not on. if you have installed the lamp door corectly and it still does this solder all three pins together on the door switch.
Oct 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
