Physical teardown boston acoustics horizon duo
  • mukesh_th902 Nov 16, 2010
    I took the item to India and bought a converter for 240 to 110V. it worked when I connected to the converter and after couple of days I reconnected the device to the converter now it does not work. I ma thinking of some issue with the power supply.
  • 6,993 Answers
please can you rephrase this question?
You typed; "physical teardown boston acoustics horizon duo", what really is wrong?
Bye for now.
Posted on Nov 15, 2010
  • Walesarumi
    Walesarumi Nov 16, 2010
    yes, its certainly a power issue, but it all depends on the extent of damage. It might simply be a fuse problem or a problem from the power board (a component may have burnt like capacitor, etc).
    If its a fuse problem, its something you can do yourself by just refusing or changing the fuse. But if its not a fuse problem, you might be needing the help of a repairman.
    Lastly, it might be that the converter you bought is defective. Test the unit with another converter to confirm this.
    Good luck.
How do you fix a boston Horizon Duo - I as the unit just turns on and makes a load humming sound and then th edisplay switches off
If you are lucky, it only went in protection mode and after disconnecting the power for a little while and reconnecting things could come back. But if the system did not have an overload protection, a fuse can be blown, or worse the power supply or power amp can be blown to pieces. There is one thing semiconductors don't like is work over their limit.
Sep 12, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Stopped working after static shock
Needs front display micro or board replaced. No parts available.
Jul 30, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Why will my volume will not go past 10 on my boston duo i plus radio?
To perform a "soft reset"(all settings are erased)
Unplug radio
Hold alarm 1 button and plug in radio
Keep holding alarm 1 button until 3 numbers appear.
Release alarm 1 button and unplug radio.
Plug radio in and all will operate normally
May 21, 2014 | Boston Acoustics Horizon Solo Clock Radio
Screen light went dark
Front board micro and backlight of LCD screen failure. Memory cap failure. No parts available, sorry.
Mar 31, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
I have two horizon duo radios and both have problems now with the on off center button. It dosesn't work. Can't turn radio off
Control micro is damaged due to leaky memory cap, .33F/5.5v on display board. Yellow glue used on these units turns brown and becomes both conductive and corrosive to the circuit board traces. built in obsolescence in my opinion to get you to buy new.
Feb 25, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Boston acountic horizon duo, how do I open it, It was connected to a 240 V and after that it stopped working. I thinking of opening it and fixing the power supply component.
hi i'm looking for that solution too but found by myself you just need to remove the 2 front speaker grille just pull off and after remove the eight rubber that retained the grille the screws is under these rubbers and after gently pry the front cabinet
Nov 13, 2010 | Boston Acoustics Duo-i Horizon Clock Radio
How to reset the clock
May i get the make and model # to help you more.
Mar 18, 2010 | Boston Acoustics Duo-i Horizon Clock Radio
My remote control stopped operating my Boston Acoustics Horizon Duo-1. I know it is not the remote because I have a 2nd Duo-i Horizon that can be operated by both remote control units. Thanks, Booker
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
Jan 26, 2010 | Boston Acoustics Duo-i Horizon Clock Radio
Unit looses time
I just received a email from BA re this issue. They were amazingly prompt and friendly. Here is what I was advised to do:
"One thing to try is to let the radio recalibrate itself, this is done by leaving the unit completely unpowered and unplugged for 48 hours to let the cap drain and the unit will recalibrate itself"
Aug 13, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
67 people viewed this question
 Grubhead
Grubhead
