Question about Bosch Classixx WVF 240S Front Load Washer / Dryer
Unbalanced During the spin cycle the machine really shakes.
  • jonre Jun 18, 2008
    Believe your problem may be inner drum bearing. I am waiting needing
    info. on how to access this part, it looks like a strip down of front
    panel to remove the drum.
    jon
Check the obvious things first. The machine has two springs which secure the top of the drum to the chassis of the machine (mounted roughly 10 o'clock and 2 o'clock as you look at the machine from the front) check that one of the springs is't broken. It also has two shock absorbers at the bottom, check them too. If the drum is secure within the machine it is probably the bearings.....
Posted on Jun 19, 2008
When the machine is on spin the machine shake so bad that it jumps
If the drum has an unbalanced load any machine will shake like crazy during high speed spin cycle - some even have a buzzer and shut down! Rearrange the clothing in the drum.
Oct 28, 2015 | Washing Machines
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
Washer shakes during spin cycle
it's possible your load is unbalanced, if this is the first time this has happened
Mar 17, 2012 | Kenmore Washing Machines
Shaking
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machine Shaking
Please take the time to give this a fix ya rating
clarkco
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
WAY too much shaking
Take out the four "shipping\travel" bolts in the back of the machine. Read the manual- it will tell you how to do this. John
Apr 29, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Bosch Classixx WVF 240S Front Load Washer / Dryer Logo
232 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
