Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
Im having trouble starting my 2 stroke chainsaw. I follow the instructions but it wont fire over it sounds like its just about to but wont.
  • 1,040 Answers
Here is a Link to one of my Tips:
http://www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!
Jim
Posted on Nov 13, 2010
  • Jim Parker
    Jim Parker Nov 13, 2010
    Sorry, but you will have to get rid of the ( http:// ) in order for the Link to work.
    Jim
Mcculloch Instructions
what im about to say, i mean no disrespect, im only saying this due to safety concerns.
If you do not know how to make this chainsaw work, Im assuming you have not operated a chainsaw before?
But for a few before starting tips, the gas is mixed with a 2 stroke oil mixture, and the oil that goes in a seperate place is a special type of chainsaw oil, not ur regular car oil. (unless however you have a new 4 stroke chainsaw, in which case it will just take regular gas)
I highly recommend finding someone who can show you how to use one of these first. This machine can remove body parts in seconds if you don't know how to operate it. and this is a different situation that the the term being careless. theres some things that hurt you for being careless, a chainsaw can hurt/kill you even if you think your doing everything correctly, but because not knowing one thing (like that the 2nd black handle forward of the solid one is the chain lockup, keeps its from coming up and eating your face or hand.) can really hurt something.
Nov 01, 2013 | McCulloch Garden
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
455 wont run
Make sure the muffler has not become plugged. Check the flywheel key as it may have sheared off for some reason causing the timing to be off, yet still generate sparks. Are the sparks blue and snappy? If not, check the ignition module gap to the flywheel magnets--use a thin business card for a gauge. A wide gap can cause weak spark. Hope this gets you running again!
Apr 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Have an old Home Lite chainsaw not used since before I had it running when I had some woods to cut a long time ago. The chainsaw (over 25 years old) won''t start when I try....not sure if it just needs a...
Replace the fuel filter, fuel lines, primer button (if equipped), and disassemble the carburetor, clean, and re-kit. Jet needles are preset at 1-1/2 turns CCW from stops (lightly). Make sure the spark plug fires a snappy blue spark when pulled through. If nothing, ignition parts prices and availability may justify replacing the saw with a new one. If sparks ok, start the engine and let warm up. Open the throttle and adjust H needle CW till the engine speeds up, but still 4-strokes. Proper setting is when the engine will 4-stroke, but immediately 2-stroke when cutting. Let the engine idle and adjust L CW so that the engine idles fairly well, but allows the engine to 'follow the throttle' Hope this helps!
Apr 17, 2010 | Garden
It is firing from the spark plug but will not attempt to start . this is a poulon pro 42cc chainsaw.
Try a squirt of starting fluid in the plug hole, replace the plug and try to start. If you get a pop or two, then you have fuel problems. Make sure you have fresh fuel mix in the tank. Check the condition of all fuel lines including the in-tank line plus the fuel filter for plugging. Check the muffler and air cleaner for plugging. Does the engine seem to have good compression? If everything looks ok, then it may be time to disassemble the carburetor, clean and re-kit it. Set both needle jet screws initially at 1-1/2 turns out CCW from the CW stops (lightly). The engine should start and run--allow to warm up. Pull the throttle full on and adjust H CW until the engine runs faster, but is still 4-stroking. The correct adjustment is for the engine to 4-stroke, but immediately 2-stroke when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Set idle speed screw to stop the chain from turning at idle, but keeps the engine running. Hope some of this helps!
Apr 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Was cutting wood when the chainsaw idled high then just stopped running
sounds like fuel mixture was wrong to lean not enough 2 stroke oil add u may have burned piston if wont start now
Jul 06, 2009 | Garden
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
242 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
