Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony tv wont start up???
Kvfq75u 32inch trinitron,just moved into new flat the tv there wont switch on its red light comes on but when you try to start it up with remote or on the tv itself the red light flashes then goes off then flashes back on again but no picture??
  • 1 more comment
  • L_and_N_Love Jul 27, 2008
    My tv has the same problem. It's 24 blinks, and on the 25th blink it stays red/lit. What can i do?
  • helperman Jul 30, 2008
    Blinks 7 times, sometimes 4 times
  • litlitaly7 Sep 29, 2008
    I have a Sony Trinitr'on that has the red light blink when I attempt turning it on; the problem is the picture doesn't come on. I never had a problem with the tv before. No warning signs of problems. I do have a 3 year old son who may have touched buttons..who knows since I was in the kitchen cooking at the time and didn't see him near it.
Have the same problem.
It was 5 blinks
Posted on Jun 18, 2008
  • 4,234 Answers
The flashing should be a repeated number of blinks. Please post that count as that will indicate the circuit in which the set detected a problem. The set is in protective shutdown. Using hte blink count, we can determine the possible problem and solutions.
Dan
  • DeDe Mitchell Mar 12, 2011
    Hi my sony KY32fs 16 is doing the same thing. There is a patter of 4 blinks. Is this worth fixing and where can I get a remote specifically for that tv?
L have 32" klv32ex300 Sony bravia of 2years old, the screen goes off after been on for some time, the green light blinks once then the red keeps blink continuously in which l will loose count after 40
id check the capacitors again,esp near the one you changed.was the one that was put in the correct one? you may increase the voltage but not the uf
Mar 12, 2013 | Televison & Video
It seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). Do you hear any clicking sounds?
Or else it could be that the CRT tube is faulty and will need to be repaired/replaced.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise.
Hope that helps!
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony bravia 32inch TV switches off after few minutes and red light blinks what is the solution
Make sure the lamp door is seated properly and back on tight. The door activates a microswitch in the TV and if it fails to do so the end result is the set shuts down with the flashing lights :
Sep 20, 2011 | Televison & Video
Television switching itself off with red light flashing.
Had same problem on a 50inch wega tv. It needed lamp replaced,not hard to replace about $180.00
from Sony.
May 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron wont turn on.
these sets have a flyback problem, the cure is usually replacement.
If you are unable to replace one, then you will require a technition.
Thanks Guy9
Jun 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
Oct 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
323 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
