Wy pc cant show my kingston. - Computers & Internet
  • 50 Answers
Try updating the driver for your kingston drive.
or simply download the driver and install.
Posted on Nov 13, 2010
Getting write error on Kingston 32gb Ultimate 600X Compact Flash Card
at the command prompt (pc/notebook) type chkdsk x: /f where x is your flash card
Dec 03, 2013 | Kingston Electronics - Others
Not detected
1stly try the Kingstone in another PC - if it works in another PC you have 1 of 4 problems:
1] You are using a very old version of Windows and therefore would require drivers for the memory stick. (i.e. Windows 95 or Windows 98)
2] Your USB ports are faulty - try the ports at the back of the PC instead of the ones in the front if you have not done so already
3] There is a virus on your memory stick and it is attempting to load an executable file when u plug it in and that is causing it to fail.
4] It is detecting fine but you cant read it because the FAT (File allocation table) is damaged in which case it will need to be formatted.
I will need some more info though - for example:
Does windows say "Hardware detected" when u plug it in?
Are you getting any lights flashing on the memory stick?
What do you see when u click on my computer? Does is show up at all but u just cant open it?
Good Luck
Feb 04, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb doesnt have a drive when i look to its properties. i cant open it either... it doesnt show on my computer. what should i do?
your pc & kingston flash driver already affected by virus ,you cannot maintain the folder options because autorun.exe is runnning, you should go to another pc ,where that pc switch off the autorun from >run>gpedit.msc> administrative templates>system>d click on turn off autoplay>ennable >d arrow>select >select all drivers>ok .go tools>folder options>view>check on all hidden files> check off hide extention........ & hide protected ........
Then after use your affected kinkstone flash driver
.Now you can see the many hidden file ,drag it and delete it or format the flash driver but your main pc should format and install the os again.
Nov 11, 2010 | Kingston (SDCZ2-512-A10-KT)...
Kingston USB DTI/1GB Malfunction error
your USB Flash Disk is damage already, you need to be repaired your Flash Disk to read again in your PC.
Jul 22, 2009 | Computers & Internet
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Files in my kingston pendrive does not open up
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
Kingston Tech Support
May 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Could not open - acess denied
Carefully examine your Kingston for a tiny physical slide switch! You have probably accidentally moved that switch into the "LOCK" position!
Hope this helps!
Feb 24, 2009 | Kingston Technologies 512MB DataTraveler I...
DATA INSIDE 32GB KINGSTON PENDRIVE CANT BE RETRIVED
I have worked through this problem. It is a new virus attack. you should get your antivirus updated and then get your drive cleaned. It surely will help you solving your problem.
Feb 20, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
