Question about Dell Inspiron 1525 Notebook
I have DELL Inspiron 1526 laptop. It displays nothing when i turn it on. The power adapter is working. The laptop itself has power since i can hear the optical drive spinning and led is also powered on. Pls help me. Thanks.
  • Dell Master
  • 32,281 Answers
The problem is most likely the back light and the fault could be the inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Nov 13, 2010
How to fix display problem in dell
<div dir="ltr" style="text-align: left;" trbidi="on">
i think this Site Will Help You. <br /><br /><a href="http://howtofixdelllaptop.blogspot.com/">How To Fix Dell Laptop</a></div>
Nov 20, 2012 | Dell Inspiron 1525 1526 PP29L US UL Safety...
My Dell Inspiron Mini won't power up. When I push the "on" button, the light indicator flashes and goes off immediately.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 21, 2011 | Dell Inspiron Mini 10 Notebook
Laptop screen will not turn on when computer boots up. The computer itself will turn on, but the screen stays black. This happens after it goes to sleep (just shut the lid) most times as well. Sometimes...
You are encountering a "POST" (Power-on self test) problem on your laptop. Here are the steps that you can try.
- Remove the battery and the ac adapter then press the power button for about 15 seconds. Try to power on the unit using just the ac adapter.
- If you have an external monitor, kindly hook it up and check if you will get any display on the external monitor. If you do, the LCD needs to be checked, if not, then you may be having a problem with the motherboard.
- If you can reseat the memory module and the hard disk drive of your laptop then that can help as well.
I hope this helps, please inform me if this solution works or not. Thanks.
May 13, 2011 | Dell Inspiron 1526 Laptop
I have downloaded a windows update (windows 7) and since my computer doesn't want to turn on. I took off the hard drive and put it back, but nothing is working. I also tried to reboot the system with...
Welcome to FixYa! Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
May 12, 2011 | Dell Inspiron 1525 Notebook
So I turn on my Dell Inspiron 1526 and all that happens is the fans fun but nothing else. No hard drive lights at all. Suggestions?
Go inti the BIOS settings and see if the BIOS detects the hard drive.
If not then re-seat the hard drive to make sure it is connected properly.
If the hard drive still isn't detected, then most likely the hard drive is faulty.
In this case to get the Dell operating again, replace the hard drive, install Windows on the new hard drive plus install the Dell Inspiron 1526 device drivers and your programs.
Jan 12, 2011 | Dell Inspiron 1526 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
My dell inspiron 1526 turns on but the screen stays black, the power light turns on but the screen does nothing
oks just check the bios settings , the memories and the hdd getting detected if no then remove the ram clean it with an eraser and put it back, if yes then plz put a windows cd and repair your os or format it
Jan 11, 2010 | Dell Inspiron 1526 Laptop
Dell inspiron 1526 has problem (plugged in ,not
Hello there:
First you will want to ensure that the power cord is fully inserted at both the laptop and all the connections for the cord and that it is getting proper power. and check tosee that the connector thatthe power cord goes into is not loose if so this will have to be repaired
next remove the battery from the computer and unplug the power cord and then press in the power button for 1 minute than if this has a reset button on the back use a toothpick or a small item and pressin on the reset button for 30 seconds
now insert the power cord (NOT THE BATTERY YET)
and turn on the computer and it should now start up if so insert the battery and leave charge for 1 hour than you should be ok from here ok
Please keep me posted on this so i can assist you if needed.
Best regards michael
Dec 16, 2009 | Dell Inspiron 1526 Laptop
Adapter is plugged in, but not charging for my Dell Inspiron 1526. Any thoughts?
turn on the machine and as soon as you turn on the machine keep on tapping f2 which takes you to BIOS screen, In the system option come to the Battery info and if it is showing battery and shows ac adapter as none it means adapter is faulty if it shows ac adapter type unknown then be prepared to purchase a new system board for your laptop
Apr 15, 2009 | Dell Inspiron 1526 Laptop
Dell Inspiron 1525 Notebook Logo
93 people viewed this question
Alun Cox
