Question about kawasaki Full Suspension Mountain Bike Men
My John Deere lx277 17 hp motor runs fine for a while then runs on one cylinder for a while then runs both cylinders .Back and forth.I pulled the plug wire off one side and tried to start it and it didn't start.I replaced the coil on the side that wasn't firing.Ran fine for a while now it is doing the same thing again.Please help!!
tellme2
  • 137 Answers
SOURCE: No fire to plugs
hi mate,, pretty rare 4 these babies to pack up ,,but if there is no spark,,1st thing u will have to get checked is the cdi box,, which operates the sparking system, as well as the coils,, rare that the coils pack up,, check the wires on the coils b4 u go any further,, make sure they are all secure,, and pull of the plug caps and just snip a bit of the ht wire ,,ie the big thick wire from the coil to the plug ,,snip a bit of the cap end so u can see a couple strands of copper wire in the core of the ht wire,, then replace the cap,, if all that is cool,, then its a cdi prob,, if u can see if u can borro one to try out,, any probs come back and step 2 il take u threw,, cheers
Posted on Mar 24, 2009
SOURCE: can't keep running seems to flood out 1978/79 kawasaki
seems your fuel to air mixture is wrong
Posted on May 13, 2009
  • 3567 Answers
SOURCE: which plug wires go to which cylinder on a 1986
This should help. Pleasse rate this answer.
Posted on Aug 04, 2009
  • 320 Answers
SOURCE: Does not have fire on the 2 & 3 cylinders.
Cilinders 1 and 4 are on the same coil, so as the 2 and 3 on the other coil.
Remove all spark plugs from engine and plug them in the spark plug leads and against the engine
To check coils easily: switch the low voltage wires from coil 2-3 to coil 1-4.
No spark at 1 and 4 is a sign that the coil is broken.
No sparks at 2-3 is a sign that the ignotion switchbox is broken, or the pick-up coils for 1-4.
Here also, switch the wires of the pick up coils. If allways the same plugs sparks, the switchbox is broken. If the other plugs sparks, then the pick-up coil is broken...
Hope it helps
Posted on Aug 22, 2009
Testimonial: "Simple, easy to understand advice. and very effective."
  • 523 Answers
SOURCE: 2003 ZR7S #4 cylinder running cool
Possibly yes; also may be a coil issue too. I had seen this same issue some time back with an older KZ650, in the end it was a coil. By stroke of luck working with the carbs put the wires back as required.
I hope this may have helped,
Tom
Posted on Oct 16, 2009
What year is a John Deere 2040 serial number 408591 L
If it is the three cylinder 40 hp diesel it is a 1981 year model. If a four cylinder 70 hp diesel 1980 model
Sep 18, 2016 | John Deere Garden
John Deere 737,Kawasaki motor, gets hot start's missing on one cylinder, cools off start's run fine, could it be the coil breaking down
possible so have the coil checked
could be from dirt and grass blocking the cooling fins of that cylinder causing the problem with mixture
if you spent that much with a dealer and the problem was not fixed maybe you should complain about the cost and the failure to fix the fault
May 13, 2016 | John Deere Garden
Where is the #1 cylinder located on a 1941 2 cylinder John Deere LA
pull both plugs and rotate motor till you get timing mark to top dead center on marker, feel for compression as you rotate motor BY HAND ONLY that will be #1
Sep 27, 2014 | Cars & Trucks
Kawasaki 17 hp stalls when hot
you need valve job done and new valves put in and i said new valves do not use old valves again 150.00 per cylinder
Sep 07, 2014 | John Deere Garden
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
Sep 27, 2009 | John Deere 3 Pt. Hitch Moldboard Plow...
John deere lx 178 1 cylinder firing
pull plug if its wet you have a firing problem if not the you have a fuel problem! been my expierence use only jd parts on that bad boy! little more $ save you several little head aches!
May 26, 2009 | Garden
kawasaki Full Suspension Mountain Bike Men Logo
174 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
