Question about Ovens
How do i change the base element in a kenwood ck480 double oven?
5 Suggested Answers
  • 1314 Answers
SOURCE: General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Posted on Dec 29, 2007
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
EllaWatson25
  • 725 Answers
SOURCE: Lower heating elements on double oven will not work
This is most likely your control board is bad. Give us a call with your brand and your model number and we will send the correct part out to you right away! We hope this gets you going before the upcoming holiday season.
Posted on Oct 09, 2009
How do you change the large base element on a kenwood ck410 oven
FIRST: SHUT OFF POWER OR UNPLUG!!! Then remove the philips head screws. remove element and replace utilizing a appliance parts vendor on line. shop for a good deal. Once you have the new element replace it the same way you removed the broken one.
Jul 10, 2016 | Ovens
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Tip
Belling Elements
on Aug 25, 2010 | Belling XOU592 / XOU593 Electric Double...
My oven door is not opening all the way. It seems to be something with the hinges.
Kenwood Oven not heating? How to replace a Kenwood fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
You searched for Kenwood element How to Repair Home Appliances
Jan 30, 2014 | Viking Ovens
Tip
on Aug 25, 2010 | Belling XOU482 Electric Double Oven
Main oven not heating up but fan is working on kenwood ck405 oven
Oct 13, 2010 | Ovens
Oven not heating up to temperature
no it does not did you change correct limiter double ovens have up to 3 and they all operate at different values.
May 14, 2010 | Neff U1721 Double circotherm Electric Oven
Kenwood ck405 - main fan assisted oven not heating up - grill working, fan working but think it might be the element - how easy is it to replace element?
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Kenwood element How to Repair Home Appliances
Feb 17, 2010 | Ovens
Oven doesn's heat up when using the conventional function.
Yes, there is probably a second element involved. you will probably find that it is located under the base of the oven. It is called the base element..
You will have to remove the rear and side panel to gain access to it.
Hope this helps solve your problem.
Dec 05, 2009 | Neff U1661 Double circotherm super...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
