When the computer is powered on, it does not boot up, but goes directly to the white screen with the hourglass in the center- no prompts or instructions appear
  • 27,725 Answers
One bad lead can cause a computer lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
Posted on Nov 13, 2010
HP Netbook mini 110, Bought new battery but it will not reboot properly after installed
sounds like it is powered up if it is continually restarting. Does it work with the AC power adapter plugged in? At any rate the constant restart is indicative of a failing power supply (not meaning the battery but the power converter that is inside notebook). After the BIOS the PC goes to the hard drive for the boot cycle at which point there is an increase in power demand which can cause a weak power supply (not the battery) to shutdown and restart, hence the restarting cycle. How do you tell him to fix the problem?? well that depends but I don't believe that there is a conversational repair at this point.
Nov 11, 2013 | Dell Inspiron Mini 10 Netbook Computer
Picture has hourglass look and has split screen picture hourglass comes and goes but split screen is continual
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Apr 06, 2012 | ESA EF427E TV
My iphone shows only white screen when i try to power up
hi,
try this solution...
1. Put phone into Recovery mode (NOT DFU)
While the phone is off, hold down the Home button and immediatly plug it into your computer. Or else.
2. From a command prompt (Start>Run>"cmd"), change to the directory where you extracted irecovery, and enter irecovery -s followed by:
1. setenv boot-args 2
2. setenv auto-boot false
3. saveenv
4. /exit
Keep this window open for use later on!
3. Run greenpois0n - it will guide you to enter DFU mode, then it will stop on a white screen after you click "Jailbreak".
It should say "Jailbreak Complete!" and NOT "Jailbreak Failed!" next to the progressbar at the bottom.
4. Extract the iBSS from your custom PwnageTool image (firmware.ispw/Firmware /dfu/iBSS.BoardID.RELEASE.dfu) into your irecovery folder.
You can use WinRAR or another ZIP extractor to do this. IPSW files are really just ZIP files!
5. At a command prompt: irecovery -f iBSS
iBSS should be replaced with the name of the iBSS that you just extracted from the pwnagetool image - ie iBSS.n88ap.RELEASE.dfu
6. At a command prompt: irecovery -s
1. setenv boot-args 0
2. saveenv
3. go image decrypt 0x41000000
4. go jump 0x41000040
5. /exit
At the "go jump" point your device should appear to reboot. Whether it goes back to a white screen or shows the Connect to iTunes screen depends on the firmware image used.
7. Restore your PwnageTool cooked or CFW firmware from iTunes.
Feb 03, 2011 | Apple iPhone 3GS Black (16 GB)
Please help! First power on, when boot up, my Dell 5150 goes directly to "Start Windows Normally" screen selection. Sometimes when boot up, screen goes to a blue with "A problem has been detected and...
Main cause of the problem is a corrupted operating system which can be cause by a virus or a defective hard disk or a defective memory module. First to try is to replace your memory with a certified good one. If the problem persists, Try to reinstall you windows using your CDRom. If there still the problem, replace hard disk.
Sep 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hi , i bought a curve 8520 3 weeks ago and it has been brill ,however last night the screen went white wiv the hourglass..i hav took the battery out for several hrs..and then replaced it...and my phone...
The BlackBerry has the feature on auto-start. When you insert the Battery, the device will automatically boot-up. It'll be showing an hour glass while loading the settings. But if it is longing for more than 10 minutes, there might be some error in the OS. It's better to contact a near-by authorised Service Center.
Regards
Vineeth K.
Aug 05, 2010 | RIM BlackBerry Curve 8520 Smartphone
No good computer stuck no good i say
While the pc is powered on, load the windows cd into the cd rom and restart the pc by pressing the CTRL+ALT+DEL keys, when the pc reboots you should see a black screen with white letters asking you to press any key to boot from the cd.
Carefully following the options install Windows and then to repair the operating system. NOT the repair console option.
If you are not asked to do a repair then stop as this solution wont work and you will likely need to reinstall Windows.
At this point windows should repair any damage files and reboot. Following the reboot, do not press any key, instead wait for Windows to boot normally, you can remove the cd after Windows boots.
Jun 01, 2010 | Acer Computers & Internet
My Toshiba boots up with Black screen with a blue box saying Enter Current Password: in white lettering.
i think its power on password The Power On password is set in the System BIOS options. It prevents unwanted users from accessing the computer. By default, does not set the Power On password. If you set the Power On password in the System BIOS options you will be prompted for it immediately after you power on the Notebook PC
if you dont know the password go for a toshiba serviceing center for solve this
Oct 13, 2009 | Computers & Internet
Hourglass of death need help
have you tried downloading and reinstalling the handheld software? if not the phone probably needs to be replaced.
Aug 03, 2009 | Sprint BlackBerry 8703e Phone
Error change unable 51
Unload the software. Restart the computer come off line. disable the anti virus Re install follow the prompts exactly. If still introuble take a look at www.fixyourownprinter.com
Aug 31, 2007 | Brother Multi-Function Center MFC-240C...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
