Question about LG Washing Machines
How do we reset the board for an lg intellowasher wd-8013f
SOURCE: HOW DO i REPLACE THE LARGER RUBBER SEAL ON A lg
I have this problem and have been told the following.
You have to take 2 Cir clips off. one on the front which is achievable by opening up the spring that holds it in place. The second one is behind the front panel.
You need to take the top off first. Undo two screws on the back top. Then you can take the top off. Then take any detergent tray our and also the front control panel. Then you gain access to some screws which hold the front panel onto the chassis.
After you take the front panel off you can apparently access the rear cir clip and spring.
once this is removed you can remove the front seal for replacement.
Posted on Sep 25, 2009
SOURCE: lg intellowasher wd-8013f not finishing
spin cycle does not start
Posted on Dec 01, 2009
  • 30 Answers
SOURCE: lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Posted on Mar 18, 2010
  • 713 Answers
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
Posted on May 13, 2010
Jahn27
  • 1554 Answers
SOURCE: I do not know how to undo the child lock on my LG
The Child Lock can be activated and deactivated by pressing and holding both the Temp button and the right Option button simultaneously for 3 seconds as shown below.
Let us know if this procedure fails to deactivate the Child Lock feature for further troubleshooting and repair advice.
Posted on Aug 23, 2010
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
My washing machine turns on but will not start. It will only make a click sound then another click sound. Please help
Your timer swicth is defective or fuse inside but check first the cord if it not broken before you go to fuse and timer
Jun 15, 2012 | LG Washing Machines
I do not know how to undo the child lock on my LG intellowasher Model no.WD-8013F
Aug 23, 2010 | LG Washing Machines
Lg intellowasher wd-8013f is very noisy
May 09, 2010 | Washing Machines
You suspect right.
Good Luck
Mar 17, 2010 | Washing Machines
HOW DO i REPLACE THE LARGER RUBBER SEAL ON A lg INTELLOWASHER 7KG WD 8013f . The seal is mildewed
Jun 15, 2009 | LG Washing Machines
It doesn't let me choose a cycle - doesn't work
the control pannel faulty needs replace ment. press the cancel/pause button and clean button together to reset the board.check it if gets reset then it will work orther wise replace control board.
Mar 07, 2009 | LG Washing Machines
Washing Machines Logo
388 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
