Question about Smeg 23 in. SER34AX1 Gas Cooktop
Ignition switch doesn't work on Smeg gas hob in house we just purchased. Model looks like SER34AX1 but may be another one. Probably about 4-5 years old. Can light burners manually, but ignition knobs are definitely there.
5 Suggested Answers
  • 1462 Answers
SOURCE: Stuck auto ignition
try easing each knob upwards a bit.
Posted on Jul 15, 2008
  • 2976 Answers
SOURCE: four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Posted on Jan 04, 2009
SOURCE: creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Posted on Apr 11, 2009
SOURCE: gas hob ignition
were do you get to refill the gas no book lost it
Posted on May 08, 2009
Cleaned my gas hob but now when you turn the gas on the automatic ignition doesn't switch on. Model candy pl 40 ax. I have checked the fuse on the plug but that's ok is there another fuse I should kno
Is it pluged in. Check to see if the plug Still works behind the stove It might be on a GFI plug needs to be reset somewhere along the backsplash counter
Jul 19, 2013 | Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
All 4 of the hobs started sparking/ clicking after cleaning the cooker top. Now they won't stop sparking/ clicking.
there is probably some water in unit that is causing the unit switches to not work. you can try to use a hair blower to thoroughly dry components.
Feb 26, 2010 | Smeg 23 in. SE64 Gas Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Stuck auto ignition
Either one of the ignition switches are stuck down internally or the ignition pack is faulty, no other possible cause. Regards Advisor
Aug 29, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg 23 in. SER34AX1 Gas Cooktop Logo
79 people viewed this question
Top Smeg Cooktops Experts
Timllfixit
ray gallant
On-Time Appliance
On-Time Appliance
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
