Question about Compaq Armada E500 Notebook
Please help I have a laptop (Compaq Armada E500) which has suddenly brokedown on me and does not work. When I turn it on it loads windows and then says the following: "autochck program not found - skipping autocheck." I was wondering whether you will be able to help me to fix this Thanks Bunny9994@hotmail.com
    Brigadier General:
  • 6,966 Answers
Based on your description, it would seem that Windows is looking for a program that is no longer there and either halts/freezes or does some other thing out of the ordinary.
Initially, suggestion/procedures are:
1. Boot in "Safe Mode", that is press F8 before Windows start to boot and arrow up to select, hit enter;
2. It may take some time but soon as Windows has booted in Safe Mode, go to "Start", click on "Run", in the next small windows, type "msconfig" less the quotes, hit enter;
3. In the msconfig window, un-check everything you feel would not be needed. They maybe updates and autochecks. Normally, what is only important is your anti-virus. Or you can try unchecking everything, restart Windows and see what programs does not run or if any glitch(es). Thereafter, you can F8 again an check to restore the missing programs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 19, 2008
My armada e500 will turn on, do the little compaq sign then just stay on a blank screen and won't do anything further. HELP!!!!
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Check if it will load to windows, if not, there could be a problem with windows. Try startup repair on advanced boot options. Hope this helps.
May 13, 2010 | Compaq Armada E500 Notebook
Desktop is part blue and part white
My husband finally found out that "web view" was checked. As soon as he unchecked it, that problem was solved.
Jun 05, 2009 | Compaq Armada E500 Notebook
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Windows 98 se, xp not installed to compaq armada E500 pc notebook
First, format the hard drive and make sure it is in FAT or FAT32 for Windows 98 install. Then do your partitioning etc and should work. If it doesn't, it is possibly a hardware fault.
Here is the site for the drivers for the laptop :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=1093
Hope this helps in some way :)
Jan 05, 2009 | Compaq Armada E500 Notebook
Compaq Armada E500
your product key may be on a sticker on the bottom of your laptop.
Aug 27, 2008 | Compaq Armada E500 Notebook
Please help
Turn off and on the power button by hand and press keys:
Ctrl+Alt in two finger and repeatedly hit the G key (if it's
not working try again by press them three the same time
down).
You will see the screen goes through some texts and
codes. And look at the bottom it say to hold down the F
key to uninstall Goback.
I held the F key for a while and let it go.
Turn the power button off by hand and back on again.( try
this method a couple of times)
If that doesn't work then try this link
http://pchell.com/support/autochknotfound.shtml
Jun 17, 2008 | Compaq Armada E500 Notebook
BIOS error
do you have the installation disk, by chance? you can boot from that and see what you can see. Just do NOT reformat the drive. I repeat, DO NOT reformat the drive.
Feb 19, 2008 | Compaq Armada E500 Notebook
PRODUCT ID NUMBER
Look underneath your laptop,theres is a sticker with number on it. usually 25 characters long.
Feb 18, 2008 | Compaq Armada E500 Notebook
My compaq Armada E500 wont come on
Replace hdd couse the pc dont recognize hdd..First go to the bios and load optimal default or optimized default and pres F10 and restart
If it wont work just buy NEW HDD
Oct 19, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
66 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
