Question about Toshiba Satellite A215-S5822 Laptop
Powers up but sceen is black - Toshiba Satellite A215-S5822 Laptop
  • Toshiba Master
  • 32,281 Answers
The problem is most likely the back light and the fault could be the inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Nov 13, 2010
Laptop sceen black
If everything else is working, hook a spare monitor to the video output, if picture okay! the inverter board just below the screen is more than likely faulty, or the backlight behind the display has failed, but if both show the same symptom it is the video graphics card usually built into the motherboard, I suggest a computer repair shop to address.
May 05, 2012 | Toshiba Computers & Internet
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
The sceen is black but wen u press the power
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 13, 2010 | Neovo AG E-17A 17'' LCD Monitor
Stefieanne, The long, thin, "cold-cathode-fluorescent-lamps" are not staying lit anymore. Unit's "switch-mode-power-supply/CCFL inverter supply will need REFURBISHMENT to restore proper operation. SOFTWARE WON"T HELP YOU!!!!! Visit all links you find while doing some reading in my fixya profile to help you in the big decision you will need to make on what you will do with this "black" or "blank n black" screen ccfl back-lit lcd monitor. Do you have soldering pencil of about 35 watts and some solder and pliers and screwdrivers and even a digital voltmeter. Contract out the work $35 to $90 Tell us what your intentions are. 12fixlouie
Mar 21, 2010 | Neovo AG E-17A 17'' LCD Monitor
No picture or sound sceen is black
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Most likely a power supply component has aged and thus changed value and/or failed. Take it to a reputable repair person.
Mar 13, 2010 | Vizio L32 32 in. LCD HDTV
Lcd touch sceen needs resetting it is misalinged
you get to the touch sceen by holdin down the frist tow buttons and turning the machine on the singer sceen will turn on just touch the sceen and you will see a small black box touch the box and it should move touch it four times and then touch the stright stiche white button at the bottum of the sceen it will save the settings and it will work .
Jan 14, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
Toshiba Satellite A215-S5822 Laptop Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
