Looking for the manual for a RS740M03A1-8EKRS2H motherboard; need to see what the SATA connections status/priority sequencing is.
  • 5 Answers
I have the same motherboard. Its a Foxconn A74MX-K 's motherboard which also adopts AMD® 740G + SB700 chipset. get the manual from foxconn website
Posted on Jun 16, 2011
Boot on sata
I found the user manual here :
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
Your problem could be in the bios. Press the delete key repeatedly while booting up to enter the Bios Setup Utility and check these options :
IDE Configuration - as shown in the manual at chapter 4 page 14
Onboard PCI IDE Operate Mode - Enhanced Mode
Enhanced Mode Support On - S-ATA
Configure S-ATA as RAID - no
and also
Boot device priority - as shown in the manual at chapter 4 page 33
set your Sata drive as the 1st boot device
For additional info, refer to the manual in the link above.
Did this solve your problem?
Dec 27, 2012 | ASUS P4P800 SE/865PE/SATA/R/A/GBE/1394...
My hard disk is 80GB (IDE) when i try to connect another hard disk 320GB (SATA) the mainboard doesnot detect 320GB SATA hard disk and my pc restart every moment note: MSI 848P NEO-V
Hello samanozy ,
Some older motherboards will not support a too wide HDD whatever the interface.
Another point is to know if you have set the boot priorities in the BIOS . Your machine is maybe attempting to boot from the Sata drive .
Best regards ,
fanaudi .
May 13, 2011 | MSI 848 NEO-V P4/Intel...
I have a Soltek SL-K8AV2-R1L with one 160 gb sata harddisk (with XP on it), a 40 gb IDE harddisk on IDE channel 0, and two DVD/CD-drives on IDE channel 1. Tried to reinstall XP but XP setup did not...
Welcome to Fixya. The first thing you need to check is if the SATA Hard Disk is detected in Bios. In the system information you will see there the list of the drives including the DVD and the IDE hard drive. You can also check the Boot Sequence or Priority if it is there. Please let me know if you find the SATA hard disk on the list.
Thanks
Apr 15, 2011 | Soltek SL-K8AV2-R1L Motherboard
Dear Technical Team, I have CPu with motherboard of GIGABYTE 8S 661 FXMP-RZ. The hard disk is working on IDE . But when I conneted another HDD connected with its SATA slot, it is not working. Would...
Can you see the sata drive in the bios? Also, are you tring to boot from the sata drive, or is it an additional drive for data storage. If the sata drive is brand new, then you probably need to partition it and format it.
Boot into windows (from the ide drive) with the sata drive connected (data and power cables). Once in windows, right-click computer (my computer in xp) from the start menu, and left-click 'manage'.
Now, click on 'disk management'. If the drive is new, you will see it in this window, and you can partition it and format it.
Please let me know if this works or not. If not, I can help some more.
Regards,
Joe
Jan 02, 2011 | Gigabyte GA-8S661FXM-RZ Motherboard
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Booting Problem
Hi there.
You will need to open your BIOS settings, and change your boot sequence/priority so that it includes PCI cards. Save and exit, and see if it then boots.
If you need anymore help, or need me to clarify anything, I'll be happy to help.
Tim
Apr 24, 2009 | Sabrent Serial ATA (SATA) 1 External + 2...
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Need help
if you have more than 1 device on the ribbon cable, make sure they are both on CS(cable select) or one is on master and one is on slave.
Next disconnect all the drives from the board and just hit the del key to enter the BIOS. Select advanced tab to make sure SATA is active, otherwise you will bypass any sata and go only to ide channels.
Once the sata is active, check boot sequence and select CD/DVD as 1st boot priority save and exit, on the reboot turn unit off and attach all cables to the board. Reboot.
Mar 19, 2008 | Abit IS7 Motherboard
Computers & Internet Logo
664 people viewed this question
David Payne
David Payne
