Question about Vacuums
IjI need a new foot control for my old Elna model. It is an Elnasuper 62c/H401048. The foot control has the ID# of 447300-1, a new power chord would be great to. I have had this machine for40 years.
Cant thread cotton correctly resulting in top cotton bunching around bobbin on my elna carina su sewing machine
Hi. Correct threading of your machine is absolutely essential for flawless function. I would suggest starting fresh, removing upper thread completely. For correct function, every threading point needs to be passed in the correct order. Every hole or thread guide should have thread going through it. Use a tweezer and pass the end of the cotton through each point, paying special attention to the tension discs and take-up lever. Double check to make sure you have light but firm tension on the thread (having lowered the presser foot, because tension is released when foot is up). Rotate the hand wheel slowly in it's normal direction to check function before attempting to sew.
Aug 20, 2011 | Vacuums
Cannot use my 1/4 inch foot as the needle is not positioned properly on my elna contessa 410
Set the stitch width to zero or set for straight stitch, as opposed to zig zag or button hole.
When you turn the sewing machine on it constantly keeps on going almost like you have your foot on the pedal all the time the machine is a contessa 410 model
the foot pedal controls the voltage to the machine. If it is running to fast then the foot control is bad
Apr 18, 2011 | Vacuums
Where can I get my Elna machine fixed? It is quite an old model and the zigzag function is broken. I am in the Toronto Downtown region.
Here is the email address for Great Western Sewing Machine Services in Toronto: brian@gwsms.com
He was the service manager for Elna, Toronto for many years.
Also, Norm Sewing Machine provides on-site servicing. Here is there phone: 416-993-4466
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Vacuums
When I plug in my power cord the light comes on but when I engage the presser foot nothing happens. This happened before so I bought a new presser foot and no problem however now it has happened with the...
I definitely can help you out here but need to know, what make / model vacuum are you referring to in your question here? It just shows "vacuum" as the item...
Please let me know, just reply to my answer here and I can help.
Thanks,
Tim
Nov 08, 2010 | Vacuums
I need a Manual for Elna Baby Lock about 10 years old
http://www.tradebit.com/filesharing.php/search/0/elna/0/1
Jul 01, 2010 | Vacuums
Foot activated power switch will not remain on
This kind of switch will turn on the power when it's pressed down a little, but must be pressed down further for it to actually lock itself on. First, make sure that you're pressing it far enough. One way to tell is operate the switch with the vacuum unplugged. You'll here it click when it locks. Make sure there isn't a foreign object or gunk stuck under the foot pedal that's keeping it from moving the whole way. Finally, you'll have to open the vacuum up, with it unplugged, and check the power switch inside. Try operating the power switch with just your hand. If you think it needs a new switch, you'll easily be able to find one, and really should be able to find one for only a few bucks if you're willing to do the shopping. Just hook the new one up like the old one was.
Dec 29, 2009 | Vacuums
Vacuums Logo
165 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
