Haven't used ipod for a couple of years! how do I set the time and date please.
  • janet hoare Nov 15, 2010
    Thankyou VERY much for the solution, all is well.
    Although I cancelled my subscription to Fixya I would be more than happy to pay as the occasion arises. It is just that I don't have a constant stream of problems that require a subscription.
    Well done.
  • 11,800 Answers
Pull up the main menu on the iPod screen. You can do this by pressing "Menu" on the click wheel.
Choose "Settings" from the list of main menu options. You will get a supplemental menu of choices. Find "Date & Time" on the list of options and select it using the click wheel. Press the click wheel to change the current time or date. The center button will take you to the next setting that you want to change. The changed time or date is immediately displayed on your iPod.
Posted on Nov 13, 2010
I haven't used my Garmin GPSMAP 292 for a couple
Have you tried pressing Page + Power at the same time while starting the 292?
Seems like there is a well Kinoen problem with the auto locate locking in wrong position and IF you reset the past position memory by pressing Page + Power while Power up should fix the problem.
You still need approx 20min location time but its better than 12-24h.
Jul 27, 2011 | Garmin GPSMAP 292 GPS Receiver
I haven"t used my camcorder for about one year and
It is likely that the flex cable that attaches your screen to the main camera is bad.
Try flipping the screen against the side of the camera and see if that makes it work, if not then a repair is probably needed.
Feb 28, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
My local time says 0146 on my ipod and i cint change the time
  1. Step 1 Turn on the iPod or access the main menu. Scan down the menu listings for "Settings." Use the click wheel to highlight "Settings." This will pull up a side-bar menu of options for the iPod.
  2. Step 2 Pick "Date & Time" from the list of options on the side-bar menu. Once again you will be given a list of options. Highlight "Set Date & Time" using the click wheel and then select it using the center button.
  3. Step 3 Use the click wheel to change the current minutes setting. When you are finished, press the center button to move on to the hours setting.
  4. Step 4 Use the click wheel to change the current hours setting. As before, use the center button when you are finished. You have set the time on your iPod.
May 03, 2010 | Apple iPod MA446LL/A MP3 Player
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
Dont know how to change the time and date on my classic Apple ipod
Hello Skipjak309,
To set date and time options:
1. Choose Settings > Date & Time.
2. Choose Date. Use the Click Wheel to change the selected value. Press the Center button to move to the next value.
3. Choose Time. Use the Click Wheel to change the selected value. Press the Center button to move to the next value.
4. To specify the time zone, choose Time Zone and use the Click Wheel to select a city in
another time zone.
Oct 25, 2009 | Apple iPod classic MP3 Player
I want to set the time and date on my calculator and need help Please give me the directions
1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
(The first digit of the date will flash)
3)Enter the date DD using the number keys.
(The first digit of the year will flash)
4)Enter the year YYYY using the number keys.
5)Press SET to confirm the date.
6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
Oct 24, 2009 | Victor 1208-2 Calculator
How do i set the time on the Jensen JiMS-190
1. If the radio / i-pod is on- turn it off.
2. Hit the 'mode' button until the time flashes (it should be 3 times).
3. Use the Tun +/- button to change the hour.
4. Use the Volume +/- to change the minutes.
5. Click through the rest of the options to change between setting the alarm, how to be woken up (chime, ipod, etc), 12/24 hour format, year, and date.
Jul 22, 2009 | Audiovox JENSEN JIMS-190-BK UNIVERSAL...
Ipod touch repeats a song over & over I have to manually advance
linda if you have not upgraded your ipod`s firmware please do it because i was facing the same problem,i upgraded the firmware and it fixed the problem.you can upgrade the firmware using itunes and clicking on check for firmware.if the firmware is already upto date then please reload the same firmware.
take care.
Jun 13, 2009 | Apple iPod touch
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Jun 08, 2009 | Microlife 3MQ1 Blood Pressure Monitor
190 people viewed this question
 Grubhead
Grubhead
