Question about Sport & Outdoor - Others
Looking for torque specs on my 1997 yamaha enticer 410cc engine
johnny5846
  • 379 Answers
SOURCE: Looking for the torque specs for 1998 chevy astro van?
1998 chevy astro 4.3 v6 torque specs include :
* foot pounds *
balance shaft (if equiped) gear bolt = step 1 = 15 ft.lbs. step2 = additional 35 degrees.
camshaft sprocket bolt = 18 ft. lbs.
connecting rod cap = step 1 = 20 ft. lbs. step 2 = additional 70 degrees.
crankshaft damper bolt = 74 ft. lbs.
crankshaft oil deflectorbolt/nut = 27 ft.lbs.
cylinder head bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees. (tighten in sequence)
exhaust manifold bolts = step 1 = 11 ft. lbs. step 2 = 22 ft. lbs.
flywheel bolt = 74 ft. lbs.
main bearing cap bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees.
oil filter adapter bolt = 15 ft. lbs.
oil pan bolt/nut = 18 ft. lbs.
oil pump bolt = 66 ft. lbs.
rocker arm with press in studs = 18 ft. lbs.
rocker arm with screw in studs = 19 ft. lbs.
valve lifter retainer bolt = 12 ft. lbs.
water pump bolt = 33 ft. lbs.
* inch pounds *
balance shaft retaining plate bolt = 106 in. lbs.
camshaft retainer plate bolt = 106 in. lbs.
front cover bolt = 106 in. lbs.
intake manifold upper = step 1 = 44 in. lbs. step 2 = 88 in. lbs.
intake manifold lower = step 1 = 27 in. lbs. step 2 = 106 in. lbs. step 3 = 133 in. lbs. ** (tighten bolts in sequence)
thanks for your vote !
Posted on Dec 28, 2008
GM Elec
  • 1000 Answers
SOURCE: torque specs for 2000 chevy silverado truck 4.3 v-6 engine
Not sure what torque spec's your looking for.
Go to www.AutoZone.com, enter your vehicle information and check specifications. You should be able to look up the torque spec's your looking for.
Good luck.
Regards,
Posted on May 02, 2009
SOURCE: need torque specs for a 85 s10 chevy with a 2.5 engine?
here you go!
Posted on Jun 21, 2009
SOURCE: snowmobile yamaha enticer manual for carberater
why don't you just check the compression if it's low fix it check the carbs make sure it works and make sure you bearing are goo your clutch your vbelt your track and that you have a the boggy wheels on it
Posted on Dec 10, 2009
wilsodfarm
  • 986 Answers
SOURCE: Torque Specs for Head Bolts on 1997 GMC Sierra V8 5.0 Vortec?
.0L Torque Specs Belhousing to engine bolts 28-38 ft/lbs Camshaft sprocket bolt 40-45 ft/lbs Camshaft thrust plate to engine block bolts 108-144 in/lbs Crankshaft pulley to vibration damper bolts 35-50 ft/lbs Cylinder head bolts -1979-1992 --Step 1 55-65 ft/lbs --Step 2 65-72 ft/lbs -1993-up --Step 1 25-35 ft/lbs --Step 2 45-55 ft/lbs --Step 3 75-85 ft/lbs Differential shaft lock bolt 15-30 ft/lbs Driveshaft U-joint to pinion flange bolts 70-95 ft/lbs Exhaust manifold bolts 26-32 ft/lbs Flywheel mounting bolts 75-85 ft/lbs Front engine mount nuts 72-98 ft/lbs Intake manifold to head bolts --Step 1 96 in/lbs --Step 2 16ft/lbs --Step 3 23-25 ft/lbs Intake manifold (upper intake to lower) 12-18 ft/lbs Oil filter insert to engine block adapter bolt 20-30 ft/lbs Oil pan mounting bolts -1979 --Step 1 (Large bolts) 11-13 ft/lbs --Step 1 (Short bolts) 7-9 ft/lbs --Step 2 (Large Bolts) 15-17 ft/lbs --Step 2 (Short Bolts) 10-12 ft/lbs -1980 to 1987 9-11 ft/lbs -1988 to 1993 6-9 ft/lbs -1994-up 110-144 in/lbs Oil pickup tube to main bearing cap nut 22-32 ft/lbs Oil pickup tube to oil pump bolts -1979 to 1987 10-15 ft/lbs -1988-up 12-18 ft/lbs Oil pump mounting bolts 22-32 ft/lbs Pinion bearing preload 8-14 in/lbs Pressure plate to flywheel bolts 12-24 ft/lbs Rocker arm fulcrm bolts 18-25 ft/lbs Spark plugs 7-14 ft/lbs Timing chain cover bolts 12-18 ft/lbs Vibration damper to crackshaft bolt 110-130 ft/lbs Wheel lug nuts 85-105 ft/lbs
Posted on Mar 16, 2010
Torque spec for crank on 2001 yz125
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
NEED HELP yz125 crank
torque specs for 1997 yz125
Yamaha YZ125N1 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 24, 2015 | Yamaha YZ 125 Motorcycles
Yamaha torque specs
The owners manual does not provide torque specs there is an on-line manual for $5 which claims to cover torque specs at: https://www.tradebit.com/filedetail.php/141315359-yamaha-waverunner-gp1200r-service-manual-repair-2000-2002
Jul 05, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
2004 YZ 125 fastener torque specs?
Torqe Specs for YZ125
Head and cylinder torque specs 06 yz125 Yamaha 2 Stroke
2004 YZ 125 fastener torque specs Google Search
YAMAHA YZ125 Owner Service Manual
Jan 08, 2014 | 2004 Yamaha YZ 125
Torque specs 2011 yz250f
complete list of 05 YZ250 torque specs Yamaha 2 Stroke
Common Torque Specs WR250R com
YAMAHA YZ250F Owner Service Manual Tightening Torques
Aug 28, 2012 | Yamaha YZ 250 F Motorcycles
2006 yz450f engine torque settings
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
06 Torque specs head bolts cam towers
http://www.bluetraxx.com/forums/yamaha-yfz450-450r-2004-present/38389-torque-specs-cam-cap-bolts.html
YAMAHA YZ450F Owner Service Manual
2006 Yamaha YZ450F Owner Manual
Jun 02, 2012 | 2006 Yamaha yZ 450 F
What is the torque spec on a 1997 yamaha seca II 600 for the spark plugs and what is the plug gap?
Hi, Torredo for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one.
Spark Plugs and Gap Settings XJRider com
Thread 650sx Spark Plug Gap Torque Specs
Yamaha XJ600 Diversion Seca II MOTORCYCLE Workshop Service Repair Manual... $10
Yamaha Diversion XJ600N Owner Manual
Yamaha 2009 Diversion XJ6S Service Manual Free
Aug 14, 2011 | 1997 Yamaha XJ 600 Diversion S-N
What are the engine head torque specs for 1986 Yamaha XT-600?
Hi, Crespindude for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
XT600E general torque settings Horizons Unlimited The HUBB
Looking for cylinder torque specs 600 twin
Yamaha XT 600 AC Service Manual
Yamaha XT500E Owner Manual
Jul 19, 2011 | Yamaha XT 600 E Motorcycles
1998 Yamaha TT 600 R head bolt torque setting
Hi, Brendenross for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Can anyone confirm head cylinder torque specs for me Put studs in dry
Yamaha TT 600 1997 Service Information
http://mybikemanuals.com/yamaha/yamaha-tt-owners-manuals
Apr 13, 2009 | 2000 Yamaha TT 600 R
Location of serial numbers on a yamaha 340 enticer?
There are 2 sets of serial numbers one set on the motor and one on the frame. The ones on the frame are on the "gooseneck", (where the triple clamps to your forks are connected). The other set on that motor are on the center cases on the top of the engine. As I recall they are just above the left side engine cover.
Dec 09, 2008 | 1974 Yamaha XS 650 A
Sport & Outdoor - Others Logo
136 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
