Question about Honda Pressure Washer PSI 3000
Only runs when I supply fuel directly to the carberator
Need to do a compresion test and a possible a valve job
Posted on Nov 18, 2010
  • danngreene Nov 19, 2010
    I solved this problem by removing the carborator. On the carb. I removed the lower bowl and cleaned it. Then on the carb I removed the sprayer with a small screwdriver from the small feed tube. I cleaned the corusion with a small safety pin, blew out tube and sprayer until I was able to observe small pass through in the tube and sprayer when looking at the sky. Inserted the sprayer back into the tube and re-assembled the carb. Started up immediately and now runs fine.
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
1995 g20 Chevy van....it has been sitting for a year...ran before...changed the fuel filter and the fuel pump in tank is running but not getting any fuel to the carberator....blew out the line goin to the...
is the fuel pump turning on? if not check the wiring harness for the fuel pump aswell as the ground. if its turning on an still no fuel, possibly could have put the fuel filter in backwards
Feb 08, 2011 | 1995 Chevrolet G20
Starts but will not keep running
sounds like you are getting enough gas tostart but not run. check the carberator bowl to see if it has gas in it. make sure your valve to supply gas from the tank is wide open. blow your fuel line back with low air pressure. it is possible you float is stuck up not letting gas flow into the bowl. remember, spark, fuel in, exhaust out. good luck
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
My 89 toyota pickup 3.0 stalls unless i hold down the gas pedel until it gets warm then it runs fine. i changed the fuel filter and the mass air flow and checked the vaccum hoses for leaks.. Still nothing
hello. Your carberator injectors are partially gummed up. go to any auto parts store and get two cans of a product call seafoam. Follow the directions on the can regarding how much you use per gallon of gas in the tank. After you have run some seafoam through the carberator it will solve your problem.
Nov 25, 2009 | 1989 Toyota Pickup SR5
2000 cavalier ran out of gas now it wont work
Remove the coveer to the carberator. Pour some gas into the carberator. If it runs you are not getting any gas to the carberator. It may be the fuel pump.
Aug 20, 2009 | 2002 Chevrolet Cavalier Coupe
Engine cant run with air filter fitted, I have cleaned it .but the problem remains the same
This means that you are over fueling. There is more fuel going to the carberator than air. By removing the air filter you are allowing more air flow into the carberator, which is allowing the engine to run right. Natural gas and propane generator must have no more than 11 inches of water column. Gasoline engines should have no more than 3.5 psi out of the electric pump. If gasoline is gravity fed, then this means that you need to rebuild the carberator or purchase a new carberator, but try to adjust the flow valve on the bowl of carberator first.
May 19, 2009 | Kipor Parallel Wiring Kit, 30 amp...
I have a Coleman Model PM0545007.01 6250 W generator with a Briggs & Stratton Model 204412 engine. It starts fine an seems to run fine (for a while). The problem is, that after about 15 minutes it...
Seems that your carberator maybe clogged at the jets. However, before you purchase a rebuild kit for your carberator make sure the fuel flow coming out of the fuel tank has a steady flow. I have seen where the fuel hole or line at the tank becomes clogged. If you feel the the fuel flow is poor grab a wire type coat hanger and clean out the hole and fuel line. Also, check for fuel filters, replace it if you have one on the genset.
May 07, 2009 | Coleman Powermate Premium Plus 6250W...
Fuel problem?
there is a fuel metering system inside carburetor that does this when it fails ..go to reputable carb shop for test and replacement
Nov 10, 2008 | 1987 Nissan Sentra Wagon
Honda Pressure Washer PSI 3000 Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
