Matrox G400/450 installed and Getting error code 12
    Problem Solver:
  • 17 Answers
I got this info from Microsoft:
http://support.microsoft.com/kb/310123
Code 12
This device cannot find enough free resources that it can use. If you want to use this device, you will need to disable one of the other devices on this system. (Code 12) Recommended resolution
Two devices have been assigned the same I/O ports, the same interrupt, or the same Direct Memory Access channel (either by the BIOS, the operating system, or a combination of the two). This error message can also appear if the BIOS did not allocate enough resources to the device (for example, if a universal serial bus (USB) controller is not an interrupt from the BIOS because of a corrupted Multiprocessor System (MPS) table).
You can use Device Manager to determine where the conflict is and disable the conflicting device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Additional comment:
It is also recommended to install drivers first before connecting any new hardware.
~aj
Posted on Jun 21, 2008
    Sergeant:
    Champion:
  • 326 Answers
Is this in addition to or inplace of the existing HD? Do U check the Bios to insure it was reconized by the pc? There should be a cd to boot up on that will preset (fdisk) the HD, did U run that?
Posted on Jun 19, 2008
Download driver free
The link below will take you to the Matrox downloads page. Just select your OS, then Product (RT.X2 SD), Software, then select the newest release and click GO. It will download the software you need. During installation it will check for the drivers and download them if needed. Hope that helps.
http://www.matrox.com/video/en/support/downloads/
Sep 19, 2013 | Matrox RTX2 SD (RTX2SDNACE)
I want to drive 5 displays from one pc. can i install a matrox 9148 and use the onboard grpahics card shipped with my pc for the fifth screen. it is an NVIDEA GEforce card.
No, you cannot do that, they are different brands, are using different video drivers and Windows cannot run more than a single video driver at a time.
Mar 22, 2011 | Matrox M9148 PCI Express Video Card
When installing matrox in wind xp 64-bits error 1275 appear
The description of this error is that the driver has been blocked from loading. Try to get the latest and compatible driver for your hardware
Apr 11, 2010 | Computers & Internet
I have matrox triplehead2go digital edition. Quit working.
Try a different USB port.
Have you checked the hardware in Device Manager? Look for Universal Serial Bus Controllers; check for RED X's.
Make sure all Windows services necessary for USB to function properly are running.
Google any errors, if found, Check event viewer for errors in RED.
Look for legitimate sites like Microsoft, Fixya, forums for similar hardware, Operating system and similar problems.
Sep 27, 2009 | Matrox DualHead2Go (D2GA2AAJ) VGA Video...
Trouble installing with windows vista 64-bit
here is the solution try to change the CD/DVD drive or your CD Disc is there an unreadable path...
Jun 18, 2009 | Matrox DualHead2Go (D2GA2AAJ) VGA Video...
No TV using Matrox G200MMS with WinXP
you need to get rid of service pk3
it may work on pk2
Jan 20, 2009 | Matrox Millennium G200 MMS Quad TV (32 MB)...
ERRor In Matrox Intellicam Software.When try to start single Grab
In most cases it means that you have a bad cable or connection so it can't sync. I'd try replacing the cable...
Nov 25, 2008 | Computers & Internet
MATROX PARHELIA 128 Mb card. When I turn on my PC it says error with this card which has been on my system for ages. I still have the original software CD. The CD installation process is not clear. How do...
A clean install is always better than an overwrite.
In Windows XP preferably in Safe Mode, to uninstall a device, you can try:
1. right click on My Computer, click on Properties, Hardware tab, Device Manager button, expand your Display Adapter, right click on the device such as your Matrox Parphelia, click on Uninstall;
2. open your Control Panel, click on Add or Remove Programs, highlight Matrox Parphelia, click on Change/Remove; and/or
3. Click on Start, click on Run, type "regedit", click on Edit, click on Find, type "Matrox", delete entry, press F3, do the same and delete all instances of Matrox.
To install, reboot your PC, insert Matrox driver/installer CD and follow on screen instructions. If it does not auto start, open/explore your CD and click on setup.exe.
Hope that this be of some help/idea. Post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
Intel onboard graphics card does not recognize two monitors connected through Matrox Dualhead2Go
You may have to upgrade to a new video card to get it to work properly. Onboard graphics are often crude with not much for options. Even a cheap video card should be good. Here are a couple of links to check compatibility:
http://www.matrox.com/graphics/en/corpo/support/compatibility/compatibility.php
http://www.matrox.com/graphics/en/gxm/support/tool/home.php
Other solution is to re-install software for the Matrox.
Nov 07, 2007 | Matrox DualHead2Go (D2GA2AAJ) VGA Video...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
