Question about Canon PIXMA MP600 all-In-One InkJet Printer
Mp 640 is very noisy and printing very slow - Canon PIXMA MP600 all-In-One InkJet Printer
    President:
  • 556 Answers
WARNING: Using REGEDT32 can cause serious damage to your operating system. Make sure to follow these steps exactly.
  1. On the Windows 2000 or Windows XP machine where the printer is connected, click Start -> Run and type REGEDT32
  2. Bring up HKEY_LOCAL_MACHINE on Local Machine
  3. In the header, click View and make sure to check "Tree and data"
  4. In the left hand pane, expand System -> CurrentControlSet -> Control -> WOW
  5. In the right pane should be a key "LPT_timeout". Double click this key
  6. A prompt for a string with a default of "15" (seconds) will appear. Change this to 3 and click OK.
Then restart Pc
Posted on Nov 13, 2010
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
You are framing a rectangular print that is 10 inches wide and 34 inches long. this wall space has an area of 640 square inches. what is the width of the frame so that the framed print fits perfectly in...
If we assume the width of the frame is X. Then the one dimension of the framed picture will be 2X + 20 and the other dimension of the picture will be 2X + 34. We know the total area of the framed picture should be 640 in^2. Therefore:
(2X + 10) * (2X + 34) = 640
If you multiply this out you get:
4X^2 + 88X + 340 = 640
Subtract 640 from both sides:
4X^2 + 88X - 300 = 0
Divide both sides by 4:
X^2 + 22X - 75 = 0
Use the quadratic equation to solve for X, with A=1, B=22, C=75
X = [-22 +/- sqr(22^2-4*(-75)] /2
This reduces to:
(-22 +/- 48) / 2
The negative solution doesn't make sense in this case. Therefore: X = (-22 + 28) /2 = 6/3 = 3
Therefore the width of the frame should be 3 inches.
Feb 16, 2011 | SoftMath Algebrator - Algebra Homework...
Hi, I have Sony Cybershot DSC w320 digital camera of 14.1 MP. Can you please tell me how I can take the pictures on less Mega Pixcal so that the size of file get reduced. Thanks, Prateek
The image size determines the size of the image file that is recorded when you take an image. The larger the image size, the more detail will be reproduced when the image is printed on large format paper. The smaller the image size, the more images can be recorded. To change the Image Size in the Camera, press and select the MENU-->Image Size-->Desired Size [(640×480)VGA or (2592×1944)5M] The quality of the VGA Image is very less when compared to the 14M.
Good Luck
Nov 09, 2010 | Cameras
Hi, how do I remove a print head from a Canon MP 640, thanks, Jenny
as i know newer canon inket pirnter, the printer head are not user removable, you have to bring it to a service center for such job..
May 11, 2010 | Canon MP640 All-In-One InkJet Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Can I change the file format on a coolpix so the
Go into the Shooting Menu, select Image Mode, and select the desired image size/quality. If you want to go all the way, select 640 for 640x480 resolution (0.3 mp).
Be aware that if you do so, the pictures won't be usable for much more than email. You're certainly not going to make 4x6 prints from them. You may as well be using your cell phone, if it has a camera, instead of a 10 mp camera.
Feb 03, 2010 | Nikon COOLPIX L18 Digital Camera
Electric start on 640 pulls dead
put bike into 2nd gear while on the bike and push backwards until the bike goes no further.put back into nuetrual.should start easier.works on my 640 when its slow to start
Mar 29, 2009 | 2002 KTM 640 LC4
IntelliFax 4100 suddenly slow to print
If the dial tone sounds NOISY or SCRATCHY there probably is a phone line problem. Try changing the phone cord first. Are you using DSL phone service?
You have a very reliable fax machine.
Nov 13, 2008 | Brother IntelliFAX 4100 Laser Fax
PRINTER NOT PRINTING
for printing both colour and black ink must be present, how is the light blinking tell me
Sep 29, 2008 | Epson Stylus Color 640 InkJet Printer
Hp laserjet 4350 printing slow down
Look on the left side of the tray. There should be 3 white fingers that stick out. Make sure they aren't broken or out of place. Also slide the paper size lever and make sure they work properly. There is also a custom and standard switch. Try to print out of the MP tray(fold down tray). If it prints normal speed, you probably have a problem with the tray.
Nov 15, 2006 | HP LaserJet 4350 Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
118 people viewed this question
old marine
old marine
