Hi i buy all pc parts but i can't fit it how can i fit it?
    President:
  • 556 Answers
Step 1: Installing the motherboardhi i buy all pc - p1010185.jpgMake sure you have all the components in place and a nice, clean and big enough place to work with.
Put your antic-static wrist ******** to prevent your components from getting affected. Make sure your hands are clean before starting. First we will be installing the motherboard which is a piece of cake to install.
  • Open the side doors of the cabinet
  • Lay the cabinet on its side
  • Put the motherboard in place
  • Drive in all the required screws
Tip: Most motherboards come with an antistatic bag. It is advisable to put the motherboard on it for some time and then remove it from the antistatic bag before placing it in the cabinet.
Step 2: Installing the CPUCPU is the heart of a computer so make sure you handle it properly and do not drop it or mishandle it. Also try not to touch the pins frequently so that they do not get dirty. Get hold of your motherboard and CPU manual. You need to place the CPU on the dotted white patch of the motherboard in a particular fashion for it to fit properly. There is a golden mark on the CPU to help you assist. Consult both your motherboard and CPU manual to see which position it fits exactly or you could also use try all the 4 positions.
  • Lift the CPU lever on the motherboard
  • Place the CPU properly on the motherboard
  • Pull down the lever to secure the CPU in place
Warning: Do not try to push the CPU into the motherboard!
Got the thermal compound? Now is the time to use it. Take small amount of it and carefully apply it on the top surface of the processor. Be careful not to put it on the neighboring parts of the motherboard. If you do so clean it immediately using the cloth.
Tip: Thermal compounds should be changed once every six months for optimal performance.
Step 3: Installing the heat sink0181.jpgAfter installing the processor we proceed to installing the heat sink. There are different kinds of heat sinks that are bundled with the processor and each has a different way of installation. Look into your CPU manual for instructions on how to install it properly.
  • Place the heat sink on the processor
  • Put the jacks in place
  • Secure the heat sink with the lever
After this you will need to connect the cable of the heat sink on the motherboard. Again look into the motherboard manual on where to connect it and then connect it to the right port to get your heat sink in operational mode.
Step 4: Installing the RAMinstallingram.gifInstalling the RAM is also an easy job. The newer RAMs ie. DDR RAMs are easy to install as you don't have to worry about placing which side where into the slot. The older ones, SDRAMs are plagued by this problem.
If you want to use dual channel configuration then consult your manual on which slots to use to achieve that result.
  • Push down the RAM into the slot
  • Make sure the both the clips hold the RAM properly
Step 5: Installing thehi i buy all pc - psu1.jpgupplypsu1.jpgWe will now install the power supply as the components we install after this will require power cables to be connected to them. There is not much to be done to install a PSU.
  • Place the PSU into the cabinet
  • Put the screws in place tightly
Tip: Some PSU have extra accessories that come bundled with it. Consult your PSU manual to see how to install them.
Step 6: Installinghi i buy all pc - 110665-2107p146-5b.jpgsrc="http://i.fixya.net/uploads/images/110665-2107p146-5b.jpg" alt="110665-2107p146-5b.jpg" class="h_mi" />First you will need to find out whether your video card is AGP or PCI-E. AGP graphics cards have become redundant and are being phased out of the market quickly. So if you bought a spanking new card it will certainly be a PCI-E.
  • Remove the back plate on the cabinet corresponding to the graphics card
  • Push the card into the slot
  • Secure the card with a screw
  • Plug in the power connection from PSU (if required)
High-end graphics cards need dedicated power supply and if your graphics card needs one then connect the appropriate wire from PSU into the graphhi i buy all pc - 042b.jpg.
Step 7: Installing the hard disk042b.jpgHard disk is another fragile component of the computer and needs to handled carefully.
  • Place the hard drive into the bay
  • Secure the drive with screws
  • Connect the power cable from PSU
  • Connect the data cable from motherboard into the drive
If your hard drive is a SATA one then connect one end of SATA cable into the motherboard and other into the SATA port on the hard disk. If your hard diskhi i buy all pc - ide-sata.jpge then use the IDE cable instead of the SATA cable.ide-sata.jpgTip: If your PSU does not support SATA power supply then you will need to get an converter which will convert your standard IDE power connector to a SATA power connector.
Step 8: Installihi i buy all pc - 027.jpgcal driveThe installation an optical drive is exactly similar to an hard drive.027.jpg
  • Place the optical drive into the bay
  • Drive in the screws
  • Connect the power cable and data cable
Tip: When installing multiple optical drives take care of jumper settings. Make sure you make one as primary and other slave by using the jumper. This is not applicable if the drives are SATA drives.
Step 9: Connecting various cablesFirst we will finish setting up internal components and then get on to the external ones. You will need to consult your motherboard manual for finding the appropriate port for connecting various cables at the right places on the motherboard.
    Connect the large ATX power connector to the power supply port on your motherboard041a.jpg
  • Next get hold of the smaller square power connector which supplies power to the processor and connect it to the appropriate port by taking help from your motherboard manual
  • Connect the cabinet cables for power,reset button in the appropriate port of the motherboard
  • Connect the front USB/audio panel cable in the motherboard
  • Plug the cable of cabinet fans
You are done with installing the internal components of the PC. Close the side doors of the cabinet and get it upright and place it on your computer table. Get the rest of the PC components like monitor, keyboard, mouse, speakers etc. whihi i buy all pc - 029a.jpgll connect now.
  • If mouse/keyboard are PS/2 then connect them to PS/2 ports or else use the USB port
  • Connect the speaker cable in the audio port
  • Plug in the power cable from PSU into the UPS
  • Also plug in the power cable of the monitor
You are now done with setting up your PC. Power on and see your rig boot to glory.
Step 10: Installing the OS and driversWe are done with the hardware part. Now get your favorite OS disks ready and the CD that came with your motherboard.
  • Set the first boot device to CD/DVD drive in BIOS
  • Pop in the OS disk
  • Reboot the PC
  • Install the OS
  • Install drivers from motherboard CD (applicable only to Windows OS)
Voila! You have your PC up and running. Enjoy your journey with your self assembled rig!
Jargon Buster
  • CPU - Central Processing Unit
  • RAM - Random Memory Access
  • DDR -Double Data Rate
  • SDRAM - Synchronous Dynamic Random Access Memory
  • PSU -Power Supply Unit
  • AGP - Accelerated Graphics Port
  • PCI-E - Peripheral Component Interconnect- Express
  • SATA - Serial Advanced Technology Attachment
  • PATA -Parallel Advanced Technology Attachment
  • IDE - Integrated Drive Electronics
  • ATX - Advanced Technology Extended
  • USB - Universal System Bus
  • VGA - Video Graphics Array
  • PS/2 - Personal System/2
  • OS - Operating System
Posted on Nov 13, 2010
Hi, what size of skin do i buy for an acer aspire 5336, also where can i buy it from
Hi
I believe that you have a 15.6" screen and you can browse here
http://shop.ebay.co.uk/i.html?_nkw=laptop+skins+&_cqr=true&_nkwusc=latop+skins&_rdc=1
i think you will need a 17" and trim it back to fit unless you can find one that says fits up to 15.6" happy hunting
Jul 08, 2011 | Acer Computers & Internet
Where to buy a wal mount for a coby led 22" flate screen television edpconsultant32@yahoo.com 312-719-4249
hi there, dont know your location but iam sure you can buy it at any appliances store or in PC parts and accessories like CDR KING , but it fit as universal wall mount.sizes vary from 15" - 32" monitor i also saw a swinging wall mount type...hope this helps....pls. vote and rate..good day
Mar 11, 2011 | Coby TFTV3225 32 in. LCD TV
Need oven knobs and the part they fit into which show the settings you need to select
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 12, 2010 | Ovens
Fittings inside dishwasher need to be replaced
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
How to Buy Appliance Parts Online
heatman101
Sep 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Where do I find replacement motherboard for Sony
hi.. please check the back plate of your branded asus case.. if its same from the clone computer you can change if not.. its better to buy clone unit cause some parts of your pc desktop could be use...
regards
Mar 17, 2010 | Sony VAIO PCV-RX403N PC Desktop
Need relacement cord for Faberware coffee maker FCP280A. What replacement cord should I buy? (3 foot)
Hi. If you have a pot that calls for a 3 wire cord, you are almost out of luck. You can not buy one. The only cord that will fit , (if it is adjusted) is the same cord that you have on your PC, everything fits but you have to dig a little trench on the part that goes into the pot Take a good long look at the part that goes into the pot and you will see what has to be done. Good luck. bobbyone
Jan 01, 2010 | Faberware FCP412 Coffee Maker
Ac adapter inside laptop isnt making a constant connection. its fairly old and the repair shop said not worth fixing its too awkward and expensive can i buy the part
Hi
You can indeed buy the DC socket and fit, however this is a specialised job and unless you are good with a soldering iron and are 100% confident to strip a notebook down i wouldnt attempt it yourself.
Generally the pricing is around £60 - £80 to do this job.
Taz
Oct 28, 2009 | EliteGroup A530 Notebook
Wetcover for casio qt 2100 where can i buy one
Hi.
Any Casio cash register dealer should be able to supply one for you. Alternatively, you can cut a sheet of clear plastic to fit. Most hardware or plastics stores sell sheets of thin clear plastic.
Oct 23, 2009 | Casio Parts Cash Register PC Desktop
Dell d600 latitude laptop
Hi
Dell Latitude D600 can only accommodate one internal hard drive. You can however install a 2nd Hard Drive as a drive module.
Check the picture below. The HDD Drive Module fits in in place of the CD/DVD Drive.
Let me know if further is needed.
Mike
Jun 07, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
