Question about TitanNet TITANTANKLESS. COM PRESENTS THE TITAN SCR2 WHOLE HOUSE TANKLESS WATER HEATE
How to reinstall heating elements. not sure about the wiring.
  • 7,733 Answers
The electrical specifications are based on 220 volts. It should be noted that higher voltage will increase power, just as lower voltage will have the reverse effect. The (POWER MODE CONTROL) can be adjusted to compensate allowing the user to increase or decrease water temperature. For best performance adjust temperature at MEDIUM FLOW (approximately 1 GPM) this is the average water flow at any faucet with an aerator.
Remember, that any adjustments made on your unit will take seconds to reach point of use. DO NOT OVER HEAT WATER. Water temperature from 105F to 120F is adequate for all practical purposes
MODELS Model Max KW at 220V Volts Max Amps at 220V N-120 11.8KW 220V 54 N-100 10.8KW 220V 49 N-85 8.5KW 220V 38 N-75 7.5KW 220V 34 N-64 6.4KW 220V 29 N-42 4.2KW 220V 19 N-10 3.2KW 110V 29*
Posted on Nov 17, 2010
I switched off the power prior to looking at this, i did not wire it. landlord replaced thermostat yesterday after the heating element had already been replaced2xs now, 0 hot. heater model 71-40sb
Is this a 220 VAC H/W Heater or a 120 VAC H/W Heater?
Note: Info provided here is for a 220VAC H/W Heater
Thermostat doesn't look like a new one, maybe it is used!
Check input power (voltage) on top two wires if this is a 220VAC H/W Heater ... then the input power from the C/B in the Electrical Panel should be 220 VAC. If 220 VAC power is not present on the top two wires ... you may have a bad C/B in Electrical panel. Make sure C/B is turned ON and if still no power on top two wires replace C/B. If 220 VAC is present on top two wires then press Red Reset Button very hard to make sure it is Reset. Then check for 220 VAC at the Thermostat ( bottom two terminals), if 220 VAC is present then check for 220 VAC on the Heating Element terminals (bottom of picture). If 220 VAC is present on the terminals of Heating Element then H/W Heater should be working otherwise Heating Element is Bad and replacement is necessary. Good Luck! Handy Henry
Feb 09, 2017 | Element Water Heaters
What else can I try, my Intertherm water heater is not heating water off the lower element?
I should like to hope I have your answer.
If yours is like most U.S. model, it is called a 220 volt unit.
That is not really 220 volts, it is really 2 separate 110 volt units.
What that means is, there are actually 2 separate 110 volt hot wires to the water heater, usually one hot wire is black, and the other hot wire is red.
One is for the upper heating unit, one is for the lower heating unit. Perhaps your lower unit has blown the circuit breaker for that line.
I mean the circuit breaker in the main fuse box/circuit breaker box.
Did you test the lower wiring to see if the hot wire is hot?
If it is hot, be sure to test the ground wire, and also the wiring between the bottom and the top of the heater inside it.
God bless your efforts.
Jan 04, 2018 | Water Water Heaters
Ariston Troubleshooting
follow this test and use the multimeter and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating element(s) and replace if faulty
.Test and replace a heating element:
  1. Turn off power at the electric panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Oct 27, 2013 | Water Heaters
My tankless RP1P is not heating well the water and is already set at Hi Temperature. What can be done to fix it?
follow this steps and fix it. God bless you
  1. Turn off power at the electrical service panel and post a sign warning others not to turn it on.
Oct 20, 2013 | Powerstream RP1P Electric Tankless Water...
Off peak hot water not heating!!! :(
The Economy 7 can control different types heater. Some heaters do not have off-peak ... but you can solve problem..
Copy following link:
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
If timer is wired to two different elements, then the night rate element or off-peak element might be burned out. Test element with multimeter.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Also this timer is wired so either Off-peak is getting power or Boost is getting power, but not both at same time.
If heater has off-peak element, then there will be a wire connected to terminal 5, going to heating unit.
If there is no wire on terminal 5, then there is no off-peak element, or wiring has not been connected. However you can change the timer function by moving wire on terminal 4 to terminal 5. Then only the off-peak timer function will operate, and not the boost.
You can also fool the timer, by setting time clock differently. Instead of setting timer for current time, rotate the dial and fudge current time by 10-12 hours so water heater thinks it's time for boost, but the actual time is during off-peak hours.
If terminals 4 and 5 both have wires, then either the element is burned out, or the timer has malfunctioned. Again, you can fool the timer by setting current time differently, and solve problem.
Apr 26, 2013 | Water Heaters
Keeps blowing circuit breaker
The most likely malfunction is that one or both of the heating elements have shorted out. The elements are not that hard to replace but does take large wrenches. The elements can be purchased at Lowe's or HD.
NOTE: I would recommend you replace both heating elements since they seem to go about the same time.
Jun 19, 2011 | Reliance Water Heaters
This water heater has two elements, correct?? Well how do you get them out?
The first thing to do is shut off power supply to the heater. Then while water is still on hook up garden hose to drain valve on bottom of heater. Place hose to floor drain or some other location for safe drainage. Open drain valve and if it starts draining at a good rate then shut water supply valve off to heater. You will want to open hot side of closest faucet to prevent vacumn which will slow or stop draining. After heater is done draining shut off drain valve and faucet . Remove the cover plates on top and bottpm of heater. Usually four small screws. Locate heating elements and disconnect wiring,label if you need to for reinstallation. There are two kinds of heating elements,one is held in place with 4 hex head bolts,and the other is screwed in. If yours has the bolts carefully remove to avoid breaking bolts.Then just pull out to remove To reinstall there will be a new rubber gasket with element, fit it in place and insert element back in heater. Reconnect wires. If there are no bolts apparent then the element screws into heater. You will need a pipe wrench or large wrench to remove the element. The same thing with this element is that it should have a new rubber gasket. Put gasket in place and wrap threads with 5 to 6 wraps of teflon tape. Install element and tighten snugly. Connect wires,refill with water and check for leaks. If no leaks then turn power back on. Put cover plates back on and you're done. I hope this helps you. Thanks
Nov 19, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
Re-connecting heating element wires
two screws on the element ... two wires ... in most cases. You probably have 220 volts, make sure it is off.
Apr 21, 2010 | Water Heaters
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How does an electrial water heater work
it uses resistive heating elements that are encased in an electrical insulation and then covered with metal, like the cooking elements in a stove, or on a cooktop range. when electricity flows through them they heat up and get hot (like a light bulb filament wire glows) When the water reaches a certain temperature set on the thermostat, it opens the electricity,turns it off to the element until the water cools down past whatever temperature it is set at, and then it turns back on. That is why if too many people take a shower you will run out of hot water because cold water is always flowing through the water heater and when all the hot water is used, you have to wait for the heating elements to heat the water back up. To make sure it heats up quickly make sure all the HOT water faucets are off so that water isn't flowing through it and is just sitting there heating up. All work on the same principle.
Nov 09, 2009 | Electra 11-1/2" Water Heater
TitanNet TITANTANKLESS. COM PRESENTS THE TITAN SCR2 WHOLE HOUSE TANKLESS WATER HEATE Logo
126 people viewed this question
Top TitanNet Water Heaters Experts
Gene Haynes
David Spradling
David Spradling
Are you a TitanNet Water Heater Expert? Answer questions, earn points and help others
