Question about Mintek DTV-260 26 in. LCD Television
Tv cycles (pops) between on (green light) and standby (orange light)
When the tv is turned on it will try and power up but there is a poping noise and the light goes to orange at the top. this repets over and over until the tv is unpluged.
DTV-260
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
50px1d-uc When I try to turn it on, the red power light blinks, I hear a click, then the light turns amber then back to red. Usually I'd hear the click then it would turn green and the tv would work...
I came across this in a manual
-Without CableCARDTM : Illuminates red in
standby mode, Illuminates green when the
TV is turned on.
-Inserting the CableCARDTM : Illuminates
orange in standby mode, Illuminates green
when the TV is turned on....
You might want to check your cable card. It seems to mimic your problem. Try taking the card out and gently clean, with a dry cloth, the contacts/strip. Then take some "canned air" and blow out the card socket from the side to dislodge any accumulated debris.
Oct 13, 2011 | LG 50PX1D 50 in. Plasma Television
We heard a "pop" noise
The pop noise could be a capacitor poping its top up.This is a common problem to most TV sets today. Usually located at the power supply board.Once this parts give up it usually shorts the circuit and blows a fuse.Replacements of these parts mentioned will often remedy the problem.Flashing power indicators indicate a problem.If you have the chance of counting how many the blinks are I could have told you the problems code are and the source of the problem.
Dec 05, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
TV will not power on.
I guess your TV is DLP.
Please notice the follow symthoms:
When you on TV, did you hear some strange noise from the back of the TV. If yes, the color wheel needs replacing.
If no, check the lamp. Take a look to bottom of lamp, you will see white pot or sometime a pop up there due to lamp cycle is going to end. When changing lamp, check the ballast and power sup, too. If you see caps are poping up. Pull out those board and replace the poped caps.
Aug 13, 2009 | Televison & Video
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
Mintek DTV-260 26 in. LCD Television Logo
105 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
