Mp3 player not working properly
I purchase a chinese mp3 player capacity 2GB. I formatted with mp3 utility tool. now capacity reach to 17mb only. it has alos one more problem i.e. it does not recognise songs after playing 10 songs & gives error "format error" . please help.........
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Please pfirst format it
if you done plz contact me again
Posted on Jun 18, 2008
After reaching the capacity of my 8gb Sansadisk, I purchased and installed a 16 gb micro sd card, but got no more memory, why not?
The Sansa Clip+ uses microSD cards. Your 16GB card is actually a microSDHC card. While it fits into the slot, it is electronically incompatible. You need to use microSD cards, 2GB and smaller.
Oct 06, 2010 | SanDisk Sansa Clip MP3 Player
Tip
FORMAT ERROR IN MP3 PLAYER
if You are experiencing "Format Error" messages when adding or accessing music/videos on your player. this could be as a result of a corrupt memory region or not having the required or supposed memory size of the player(actual memory)
what you do you should format:
formating Ensures that what you have bought, is of the actual memory capacity.
. 1. You will not lose any firmware/theme related files.
2. You will not accidentally kill your player whilst doing so (unless you unplug or disconnect your player during the format process).
follow the step below to guide you
STEP 1
Back Up All Your Data Before Proceeding! This Guide Will Clear Everything In Your Player's Memory Chip!
Install MP3 Utilities, any version will do. It usually comes on the CD with the player, or you can download version 3.68
Here, or version 4.03 Here, or version 4.05 Here. Any one of these will do. The Disk Tool Utility is the same.
STEP 2
Start up MP3 Utilities Disk Tool.
You will be shown a screen like this:
Ensure that you select LOW Format Type.
Next, go to the Partition and Encrypt tab as shown below.
Now, slide the Partition Slider all the way to the Right.
You will notice the "Setting encrypted disk capacity" increases, it is normal.IMPORTANT.IF YOUR MP4 PLAYER IS LIKE 2GB OR MORE MAKE SURE THE PARTITION AND ENCRYPT TAB WHEN YOU INCREASE IT SAYS YOUR PLAYERS MEMORY.FOR EXAMPLE.IF YOU HAVE A 4GB MP4 PLAYER AND YOU ARE SLIDING THE PARTITION AND ENCRYPT TAB MAKE SURE THAT WHEN THE NUMBER INCREASES IT SAYS SOMETHING LIKE 4000MB.IF IT DOESN'T DO THIS DO NOT REPEAT DO NOT DO THIS ENTIRE PROCESS.
*NOTE* Ensure That You Do Not Click The "Set Username And Password", Leave It UNTICKED.
Next, click on Start to begin the format and partition process. You will be presented with a dialog box like below, click on Yes to proceed.
It will take a few moments for the process to complete. You will notice that your player would disconnect from the computer, and then re-connect back again.
You will be presented with the "Complete setting disk partition!" dialog box like below.
STEP 3
Go to My Computer and check that now you will two memory drives for your player. You might need to click Refresh or press F5.
One of which would be small (about 17MB), and the other would be the remaining memory capacity.
Do not worry if it does not appear, just continue to with the guide.
then go back to the Partition and Encrypt tab.
Slide the Partition slider to the Left, and click on Start.
repeat the process and the "Complete setting disk partition!" dialog box would appear.
Check in My Computer that now you will only have One single memory drive for your player. Right click on it and select Properties, this is your actual real memory capacity.
Now check your player's Memory Info for the correct memory display.
To access this, go to your player's SYS TOOL >> MEMORY INFO.
Your player should display the actual memory size that you have just checked.
Check if the percentage is at 0%. If it is, you can skip Step 4 below, and continue to Step 5.
STEP 4
If your player's Memory Info does not show 0%, you will need to complete the below procedure.
Right click on your player's memory drive, and select Format.
Now a new windows format screen would appear.
Select FAT in the File System dropdown menu.
If after completing Step 3, your player really does have 4GB of memory, then you need to select FAT32 instead. As FAT only supports upto 2GB.
Click on Start to begin on the format process.
A warning will appear for the format, click on OK to continue.
Wait for a few moments while Windows formats your player.
When completed, check your player's Memory Info again, it should display 0% now.
STEP 5
Once completed, start copying music/video files to your player and enjoy enjoy your player
on Dec 19, 2009 | Audio Players & Recorders
My mp3 is all ******** u know,whenever i put songs in it,FORMAT ERROR occurs when i play it,dont know what is ******* it up.if anyone can fix this problem please help.thanks.
STEP 1
STEP 2
STEP 3
STEP 4
STEP 5
Once completed, start copying music/video files to your player and enjoy enjoy your player. hope this helps
Dec 19, 2009 | Apple iPod nano
How can i repair the corrupted memory of Chinese MP3
The brand and model name will help more for a better solution.
Try to format the memory area.
Good Luck
Aug 20, 2009 | Audio Players & Recorders
2gb pen drive display 268 mb
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Aug 02, 2009 | Transcend T.sonic 612 MP3 Player
I have 2GB pen drive and i have coming problem to format it
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
May 01, 2009 | Pen Drive IVO MP3 Player
Format error in LG MP3 player CM60022 ACT_V9.1.52
first, go here and download the utility:
http://mp3-player-utilities.software.informer.com/
Then:
You will repeat the process and the "Complete setting disk partition!" dialog box would appear.
Then Format again your player on Windows..
Jul 21, 2008 | iLO (2 GB) MP3 Player
TECH SUPPORT HELP
real ipod - go to apple, search reset utility.
Fake ipod (itunes hates it) go to ebay guides and read about fake capacity mp4 players. Use the test software suggested.
Feb 16, 2008 | Apple iPod nano
Ipod 4gb error
I had the axact same problem and these instructions fixed it:
This guide is for you if:
1. You've bought a mpx player larger than 2 GigaBytes capacity (eg 4GB, 8GB, 60GB, etc). Not limiting to larger than 2GB, smaller capacity (eg 512MB, 1GB, etc) players are also subjected to possible memory hacks.
However, recently i've realised that the Actions chipset does support upto 4GB (2x2GB). Also, there were some unconfirmed news of genuine 4GB players.
2. You just bought a new player.
3. You are experiencing "Format Error" messages when adding or accessing music/videos on your player.
4. You are experiencing frequent Player Restarts (hanging on the hourglass) when playing certain songs.
5. Your player duplicates the music/video files that you add to it.
6. Your player does not allow you to move/delete files that you have copied to it.
If you fit any one of the above (or even all), then this guide is for you.
Why you should format:
1. Not formatting will only cause you ALOT of trouble and hassels in the future.
2. Not formatting increases the chance of killing your player in future, and you will need to perform the "Dead Player Recovery".
3. Ensures that what you have bought, is of the actual memory capacity.
4. If it is a gift for someone, you don't want them to come back to you with the above mentioned problems.
Common Myths regarding this formatting procedure:
On completion of this guide, should you end up with lesser memory than what you have paid for, it would be recommended to contact your seller for a full refund.
Also, take a minute to fill in an online petition against eBay, Paypal and fraudalent sellers who knows about this problem, but persists to trade with such fraud items for monetary gains.
http://www.mympxplayer.org/petition-stop...ay--vt3442.html
Every signature plays a significant factor, the more signatures we have, the better chance of eBay shutting down such sellers permanantly.
STEP 1
STEP 2
STEP 3
*note* it seems that some members reported that they do not see this extra drive appearing. Do not worry if it does not appear, just continue to proceed with the guide.
Now, go back to the Partition and Encrypt tab.
STEP 4
STEP 5
Once completed, sit back and start copying music/video files to your player and enjoy your stuff!
Dec 27, 2007 | iLO (2 GB) MP3 Player
Storage problame
I Would Suggest Using iTunes To Reformat It. iTunes 7 Includes Reformat Software For Every iPod Model.
Sep 08, 2007 | Apple iPod MA446LL/A MP3 Player
89 people viewed this question
 Grubhead
Grubhead
