Question about Zebra 105SL Thermal Label Printer
Paper Out Printer is saying paper out constantly
  • 2 more comments
  • Anonymous Jun 28, 2008
    printer is flashing out of paper but has paper in it?
  • helpdesk041 Jun 28, 2008
    Zebra 105SL showing out of paper when it actually has paper in it.
  • Anonymous Jul 22, 2008
    Same problem here. Zebra ZM400, Error condition: Paper Out
  • hunter_Q2 Apr 27, 2009
    Zebra ZM400, first got error: "ERROR CLEARED RIBBON OUT", even though the ribbon was loaded. I recalibrated the ribbon, and cleaned the red sensor and the thermal pad above the ribbon film. Now I get "ERROR CONDITION PAPER OUT"
Try to clean the sensor and press the cancel button two times, and it works! on zm400.
Posted on Jan 09, 2012
pineworks
  • 4041 Answers
SOURCE: Printer keeps saying there is a paper
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
SOURCE: the printer is constantly sending a message- 'paper jam'
mprinter hp deskjet 3320 is not sucking the paper from the trah. It is making al kinds of noises but not printing what is the problem?
Posted on Feb 17, 2010
SOURCE: "reload paper" message
Lower paper sensor was completely dusty. Just blowed it and it works.
Posted on Apr 15, 2009
alkhaled
  • 12 Answers
SOURCE: On a Canon MP 460
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Posted on Oct 21, 2008
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Posted on Sep 07, 2008
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
My Fuji Xerox C525A constantly says that the bypass tray is empty when it is not. I have to remove the paper and slide it back in and it will print 2 pages and then I have to remove the paper and slide it...
make sure you have the right paper size settings. The paper loaded in the tray might be shorter than the setting in the document. Check also the output size in printer setting.
May 20, 2010 | Xerox DocuPrint C525A Laser Printer
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Printer says jammed , cleared printer completely, still says jammed , no evidence of jam,disconnected printer, reconnected, ,still says jammed,
The possible reasons for this could be
  1. (For Laser Printers Only) Toner sediment in the fuser unit. This specially occurs if you constantly use smaller paper sizes than the paper tray size. To resolve this you should disassemble the printer, take out the fuser unit and clean the toner sediment. The sediment can get rock solid so clean it carefully. If you are not accustomed with electronic components better visit a technician.
  2. The paper sensors pulling spring may be detached. In this case the sensor gets a message that some paper exists in the fuser unit so a paper jam message is triggered. Fix the spring and you are done.
Nov 27, 2009 | Office Equipment & Supplies
Hp deskjet constantly says out of paper. As far
Each printer has a sensor that determines when there is no paper, on cheaper printers like deskjets it tries to feed the paper and when it fials it gives this error. The feeder for the printer is most likley bad, replcaement is the most cost effective solution , repairing it would be more then a new unit.
Aug 25, 2009 | HP DeskJet 612c InkJet Printer
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
Dec 23, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer says it is jammed
unplug printer from wall for 12 secs and plug back in
Jan 15, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
Zebra 105SL Thermal Label Printer Logo
3,012 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
