Question about HP Color LaserJet 2600n Printer
My HP Color LaserJet 2600n is printing with the yellow portion of teh print aff the image to the right. Is there some way I can align this cartridge back to where it should be? I changed cartridges thinking it would solve the problem, but is still the same.
    Guru:
  • 254 Answers
Hello user
you can align the toner thru the printer settings of the printer itself, calibrate, clean and after all of that is done but still the same, check the fuser maybe it is little dirty, and at the back of the toner there is transparent like glass clean that part and try again.
thanks
Posted on Nov 13, 2010
When I print on my HP Color LaserJet 2600n Printer the far right(1 inch) of the page is faded and is unable to be read. I have replaced the ink cartridge but it doesn't help
Have you cleaned the print heads? There should be a program that came on the drivers disk that includes a "service" tab where you can align and/or clean the print heads automatically. If they are particularly dirty and have never been cleaned, you may have to run it through two cycles to get it right.
Oct 05, 2011 | HP Color LaserJet 2600n Printer
I have a HP Laserjet 2600N in my offie that is connected to the network. It is printing too much of yellow when printing any documents with colour. Please advise. Thank you
open the front where the cartridges, check if you notice runny yellow toner and toner surely you'll find under ', which replaces the yellow cartridge is probably refilat
May 25, 2011 | HP Color LaserJet 2600n Printer
Sir i have hp 2600n i have a problem my hp 2600n prints blur image or prints double image what can i do plz tell me
Try to fix the paper size from printer preferences, and check whether the printer cartridges are aligned, u can always align the printer cartridges by navigating the printer menu to the settings and then align printer cartriges. good luck
Mar 12, 2011 | HP Color LaserJet 2600n Printer
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n imaging problems
try the clean heads and alignment in the print manager..
Aug 20, 2008 | HP Color LaserJet 2600n Printer
Hp 2600n color printing problem
are you using orgnial hp cartridge if not check that it may cause due to that. check the black sheet fro color spreading , if there is any color pls clean that.........
Thank you
Feb 19, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
