Question about HP P2035N LaserJet Monochrome Printer
Get out of paper error on hp p2035n add paper out off paper indicater when off. But the printer queue stil say out of paper. Tryed powering off and on. Still get out of paper error on the printer queue.
    Guru:
  • 254 Answers
Hello dear user
unplug the power of the printer and shutdown and start your computer.
let me know what will happen.
thanks
Posted on Nov 13, 2010
My printer prints the same document over and over even though the queue has been cleared. It is not a test page, but a different document that we had tried to print when it wasn't printing initially.
In the right bottom of the computer screen you will see the printer icon. Click it open and delete the print queue. Now when you order a new doc there is nothing but the new doc to print. If this does not work then re-install the printer drivers.
Oct 29, 2013 | HP "LaserJet P2035n Printer"
Using HP laserjet P2035N model. It is connected to the network with IP. When giving printing private software named "GP" we need to press the botton at the top of the printer. Then only the print is...
The reason you need to press the print button is because of the mismatch between the two paper sizes, this is normal. Find the manual and follow the instruction on how to change the paper size on the printer, or change the paper size in your software. Either should work. They must be the same for it to work properly.
Aug 26, 2017 | HP P2035N LaserJet Monochrome Printer
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
HP LJ P2035n print from Dos problem
win xp has dropped the printer driver
as it is no longer supported by Microsoft get it from the printers manufacturer web site
Jan 24, 2018 | HP "LaserJet P2035n Printer"
P2035 incorrect margin output
The page size its correct?(paper, A4,letter....etc).
Do a test page on windows and see-it.
Check the size of paper!
Apr 10, 2012 | HP P2035N LaserJet Monochrome Printer
My HP P2035N LaserJet is saying it's "offline"
Offline means that the computer thinks the printer is not available. The problem is that some how, that option in the printer menu has been checked. "use printer offline" is the choice that has probably been checked. Some times this will happen after a communication or paper problem has occcured.
To get to this menu, go to printers and faxes on the control panel. Find your printer icon and click on it.
A window wil appear and you will see file in the upper left corner. Click on this and a drop down menu will appear. You should see the offline option here, and if there is a check mark in front of it, click on the check mark to remove it.
This should clear the problem.
May 24, 2011 | HP P2035N LaserJet Monochrome Printer
The third symbol from top of the HP printer P2035N is flashing and i cant print
The third symbol for the P2035N printer is the paper out light. Refill the paper tray or replace the paper or other media with a supported type. Then press the Go button (the upper of the two buttons at the bottom of the control panel). See the User's guide which is available here: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&docIndexId=64255&prodTypeId=18972&prodSeriesId=3662025&lang=en&cc=us#4 .
Supported media is listed on page 31. The status light codes are on page 78.
I hope this helps.
Feb 12, 2011 | HP P2035N LaserJet Monochrome Printer
The arrow light wont stop flashing
this is common issue when paper jam or errors in printing queue,, check for any paper stuck inside (open up the back bay) delete the printing queue, power off printer restart the computer ! you should get solid green light
Dec 15, 2010 | HP Deskjet D4260 Printer
HP P2035N LaserJet Monochrome Printer Logo
1,320 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
