Question about Nokia 6230
Nokia 6234 Charging circuit
Hi I have an Nokia 6234 that says charger not supported , no matter which approved nokia charger i use. I'm unable to charge the battery now and the phone has become useless. Is there any fix available for this problem?
Many thanks
Peter
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
No, take the battery out and bring it to an auto part store and they can test it.
Posted on Jun 18, 2008
My Nokia 6234 is not accepting my sim card, i need Restriction code, my IMEI number is 359395002773712
your phone is lock
try these sites
http://www.gsmliberty.net/shop/nokia-6234-imei-unlock-codes-p-1758.html
http://sim-unlock.net/simlock/Nokia/6234/
Mar 19, 2013 | Nokia 6234 Cellular Phone
RESTRICTION & MASTER CODE FOR NOKIA 6234. IMEI-359395003537405
Hi, To which network has your Nokia 6234 been locked to? The safest and easiest way to unlock a mobile phone is to unlock using unlock code. An unlock code for a Nokia mobile phone can be obtained either from the respective network provider or from any trusted vendor online. for example, An accurate unlock code for a Nokia 6234 can be obtained from www.simpleunlocking.com/nokia-6234/rs16wp9/ at affordable cost. This site provides accurate unlock codes for over thousands of mobile models at low cost with easy unlocking instructions.
UNLOCKING STEPS FOR NOKIA 6234
1 - Switch on your Nokia 6234 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6234.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6234 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6234 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6234
The master reset for a Nokia 6234 can be done through any Nokia Priority dealer.
Oct 22, 2012 | Cell Phones
Nokia 6234 restriction code
Hi,you can try Simpleunlocking.com to get restriction code for your Nokia 6234 and get it unlocked..
Feb 13, 2012 | Nokia 6234 Cellular Phone
When I swtch on my nokia 6303 classic it say battry low and it beacome off I want hole formate code
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 5.5px Helvetica} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 8.0px Helvetica}
I found this information in the manual, I I think it should address your problem:
The battery can be charged and discharged hundreds of times, but it will eventually wear out. When the talk and standby times are noticeably shorter than normal, replace the battery. Use only Nokia approved batteries, and recharge your battery only with Nokia approved chargers designated for this device. Use of an unapproved battery or charger may present a risk of fire, explosion, leakage, or other hazard.
If a battery is being used for the first time or if the battery has not been used for a prolonged period, it may be necessary to connect the charger, then disconnect and reconnect it to begin charging the battery. If the battery is completely discharged, it may take several minutes before the charging indicator appears on the display or before any calls can be made.
Always switch the device off and disconnect the charger before removing the battery.
Unplug the charger from the electrical plug and the device when not in use. Do not leave a fully charged battery connected to a charger, since overcharging may shorten its lifetime. If left unused, a fully charged battery will lose its charge over time.
Always try to keep the battery between 15°C and 25°C (59°F and 77°F). Extreme temperatures reduce the capacity and lifetime of the battery. A device with a hot or cold battery may not work temporarily. Battery performance is particularly limited in temperatures well below freezing.
Do not short-circuit the battery. Accidental short-circuiting can occur when a metallic object such as a coin, clip, or pen causes direct connection of the positive (+) and negative (-) terminals of the battery. (These look like metal strips on the
battery.) This might happen, for example, when you carry a spare battery in your pocket or purse. Short-circuiting the terminals may damage the battery or the connecting object.
So, essentially, you probably need a new battery.
Good Luck!
May 29, 2011 | Nokia 6303 Cell Phone
Nokia 6234 long time charging and won't stay on
I had a nokia 6233 and a nokia 6234 and at both of those phones i had the same problem. This happens when the battery was used with other handsets before or when the battery is quite exhausted. Buy a new one!
Nov 03, 2009 | Nokia 6234 Cellular Phone
Nokia 6234 Security Code
Hi
Its 12345 . For more information refer to the user manual for Nokia 6234 from the following link :
http://nds1.nokia.com/phones/files/main_page/Nokia_6234_Vodafone_UG_en.pdf
Thanks
Rylee
Jan 15, 2009 | Nokia 6234 Cellular Phone
Nokia 6234 restricition code for free
You can get the codes from cellular shop or your phone technical company
Feb 28, 2008 | Nokia 6230
Nokia 6230 Logo
181 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
